Key Less Ignition Failure - Victory Forums - Victory Motorcycle Forum
 2Likes
  • 1 Post By toejam
  • 1 Post By SuperDog
post #1 of 7 (permalink) Old 06-09-2016, 05:28 PM Thread Starter
Default Key Less Ignition Failure
Went to go home last night after work, put away work bag and went to turn on the ignition to start and the alarm goes off. If you havn't heard it, it's unbelievably loud. I'm unable to stop the alarm with the key fob. The alarm just keeps going.
Very frustrating and embarrasing.
So I made a call to Scorpio and they were not of much help.
I called the wife to have her bring the other key fob, and she was on her way to save me.
I called the local Victory dealer and talked with a tech and all he could suggest was to pull the fuse to the ignition (right side cover), and diconnect the battery.
The thing won't shut up, alarm still wailing. Didn't know it but it must have it's own internal battery.
My wife shows up with the other fob and it finally stopped. Put everything back together and started it and went home.
What I can't understand is I've been using the fob I usually use for over a year with no issues and it was almost fully charged? I don't know if diconnecting the ignition fuse and the battery helped it out?
Anybody have any thoughts? I havn't done anything with it since I got it home last night?
My thanks in advance!
2014' XC Titanium Seude
Previous, 07' Yamaha FJR
Draper, Utah
Draper is offline
post #2 of 7 (permalink) Old 06-09-2016, 06:08 PM
Motorbikerx's Avatar
Keyless is great till it stuffs up
Personally I prefer a good old fashioned key.
Seen way too many people have expensive problems with keyless systems in cars.
Sorry I can't help.
Motorbikerx is offline
post #3 of 7 (permalink) Old 06-10-2016, 01:24 AM
toejam's Avatar
I'm thinking the battery in the remote died...
depot picker likes this.
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #4 of 7 (permalink) Old 06-10-2016, 05:32 AM
Bucky5454's Avatar
Send a message via Yahoo to Bucky5454
Default Same issue
I have one key fob that will work with the bike the other wont. If I arm it with the one that works the other key fob will beep. Also the alarm goes off on it but it will not control the bike!
US Army RETIRED
2015 Victory Magnum Ness
Mini Apes
Lid Speakers
Back Rest
2012 Victory Highball
Stage 1 Swept
Vic Cruise Control
MBW Rear Turn Signal
Curved Swingarm mounted Lic Plate
Stebel 139db Air Horn
Bags
Bucky5454 is offline
post #5 of 7 (permalink) Old 06-10-2016, 05:52 AM
JJKJR's Avatar
I had the same problems with my Scorpio i800 alarm. Vitually anything that I did to interrupt power to the alarm (disconnect battery cable) or change the battery in the FOB caused it to go off and not stop. In the back of the instruction manual there is a Master Reset Procedure that I had to do several times to get the alarm to turn off. It wasn't an easy procedure to do with one person. After the last incident, I called Scorpio and talked to one of their techs who was very informative. He told me that their alarms are made to do that so that a loss of power wouldn't make stealing a bike easy. I ended up taking mine off the bike. At some point, I'm going to go with a wheel lock alarm.
2014 Havasu Red XC
2004 Black Suzuki Volusia
JJKJR is offline
post #6 of 7 (permalink) Old 06-11-2016, 10:32 AM
SuperDog's Avatar
LOL, now tell me, did anyone question you, did the cops show up and question you, etc?? If not, ask yourself, how worthwhile is something that causes headaches and problems and does NOT prevent theft. I will stick with a key, and I always carry a spare, just in case.
Motorbikerx likes this.
"Be Water, My Friend" Bruce Lee 1971
2013 CCT Grasshopper Drivers Backrest, PVC Self Made 1/4 turn Throttle Ring, Thrush Self Modded Mufflers, Kuryakyn 4526 Tour-Tech Adjustable Cruise Mount/Tour-Tech Pegs
SuperDog is offline
post #7 of 7 (permalink) Old 06-11-2016, 11:57 AM
No suggestions but you certainly gave me my first laugh of the day. I'm sure it wasn't funny at the time but it will give you a great story to embellish over a few pops.
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
