Low/moderate speed wobble and looseness - Victory Forums - Victory Motorcycle Forum
 7Likes
post #1 of 26 (permalink) Old 06-14-2016, 10:18 AM Thread Starter
Supesguy's Avatar
Default UPDATE: Low/moderate speed wobble and looseness
I have searched this is bit before posting, but most issues seem to be pertinent to higher speeds. My bike is a 2014 Cross Roads 8-Ball, bought new from a dealer August '15. It now has about 2,000 miles on it.
A few weeks ago, I began noticing an intermittent wobble or sensation of the rear end feeling loose when going around a corner. It feels like as if the rear tire was super deflated or flat, but it's not. I don't notice it all the time, but this past Sunday it began to feel more regular, almost with every turn, particularly left-hand turns. I was on a large charity ride, cruising about 40 mph on a section highway. At first I thought it was those tar-filled cracks/seals on the road that were influencing the tires. When we turned left off an exit onto a local road, I felt like it had a pronounced slide, wobble, or looseness in the rear end.
That was enough to make me pull the safety card and pullover out of the pack. A buddy stopped with me and we proceeded to pull the hard bags and visually inspect everything we could. The rear tire pressure was fine at 40 psi (front was fine too). The rear shock (which I hadn't adjusted since I bought it) seemed to barely register on the tire pressure gauge, if at all. We hand checked the tightness on bolts surrounding the axle, swing arm, pulley, etc. Basically anything surrounding the drive train, we tried to check on the spot. We didn't find anything with our bare hands. My Harley riding buddy stated he felt like the belt was really tight. I honestly couldn't give a good opinion on the matter, but it seemed pretty tight to me too. The alignment marks for the axle bolt are in the same position on both sides.
More on the shock pressure. We decided to put some air into the shock. Once we found a gas station whose air filler would fit on the valve, we put enough air into the shock to bring it to 25-30 psi. I'd say there was 0-5 psi previously. This did cause a noticeable lift in the bike. We kind of laughed at how pronounced it was. Now, I weigh about 185-190 lbs. Probably 195ish with all my gear on. I did have a little bit of cargo in the saddle bags, largely rain gear in one side and a couple 16 oz bottles of water in the other. I did not have a back rest, trunk or passenger on the bike, so I had never added air to the shock.
I am supposed to be going on a trip next Thursday (6/23) over 4 days with the bike. Of course, I am being very cautious and want to be sure the bike is safe for such a long trip. The local dealers are busy as expected, so they can't get a proper service appointment set for a couple weeks out. One dealer (thank you Falcone Powersports!) did offer to give the bike a once-over squeezed in next Wednesday to check the belt, test ride, and give as much quick glance to it as they can before my trip.
Any other suggestions? I'm kind of in panic mode on trying to sort this out before my trip next week.
Greenwood, IN
Supesguy is offline
post #2 of 26 (permalink) Old 06-14-2016, 10:42 AM
adamnorthup's Avatar
Make sure the rear wheel is straight in the swingarm. You can get all kinds of weird chassis wiggles from inconsistent tire patch.
adamnorthup is offline
post #3 of 26 (permalink) Old 06-14-2016, 10:55 AM
A wobble can be the result of many things. I found that my XR came with loose Steering head bearings, so check them for proper torque. I discovered that when the bike was on the lift and I could yank on the bottom of the forks and feel back and forth movement.
I average around 30psi in the shock--40psi when loaded. An aired up shock will help with handling.
post #4 of 26 (permalink) Old 06-14-2016, 10:56 AM
Garion12's Avatar
Bad tire? May just be a fluke with a bad patch of rubber.
Keep air in that shock, it really helps with the ride quality and cornering.
2010 Cross Roads
Lloydz Air Filter
Lloydz Slip on Exhaust
Lloydz Timing Wheel 8*
LLoydz VM1-HPT Cams
Lloydz reflesh 6500 rpm
Dyno tuned by KMC 123 hp 121 tq
Garion12 is offline
post #5 of 26 (permalink) Old 06-14-2016, 11:11 AM
first off all belts will tighten up after ridding. Its just normal.
The inside of the tire could have bad cords even if the outside looks good.
You haven't said if adding air to shock help.
I would say go out and ride it again before the dealer gets it.
Try running it up to 70 mph and back down. Maybe your friend can ride with you. Even leave the bags at home so he can see the rear wheel.
If you can afford it put a new rear tire on or have dealer take it off the rim and inspect it and rebalance it
RICZ likes this.
post #6 of 26 (permalink) Old 06-14-2016, 12:18 PM
Supesguy, Sorry to hear of your wobble issues.
Hope you get it resolved quickly and easily!
Please report back when you do, I think we are all curious?
2014' XC Titanium Seude
Previous, 07' Yamaha FJR
Draper, Utah
Draper is offline
post #7 of 26 (permalink) Old 06-14-2016, 12:26 PM
VJ mentioned broken tire cords as being a possibility and I concur. There may be an indication of that if you feel the tire for a slight bulge with the flat of your hand.
post #8 of 26 (permalink) Old 06-14-2016, 12:48 PM
I had a front bubble the tread off the outside of the cord casing as well - leaked thru the inner rubber somehow.....
post #9 of 26 (permalink) Old 06-14-2016, 01:50 PM Thread Starter
Supesguy's Avatar
Thanks for the input guys! Sorry, I forgot to comment on the effect of adding air to the rear shock. It did help! The bike definitely seemed much more poised and consistent through the curves. However, I still think I'm feeling the looseness/symptom on occasion. Again, it seems prominent when making left-hand turns. This could support many of your comments about a tire cord being broken or something else wrong with the tire. If there is a defect in the tire on the left and the tire gets loaded with force accordingly when making a left hand turn, I could see where the symptom could arise.
As for belt tightness, it's amazing how much it tightens up when hot. Wow!
I will have to research how to check wheel alignment prior to have the dealer look at it next week. Although, it almost makes me wonder if I should have the rear wheel removed and tire inspected first. This sucks, all these things cost money with no guarantee of problem resolution. I expect a new rear tire to cost ~$400 after labor/service.
Greenwood, IN
Supesguy is offline
post #10 of 26 (permalink) Old 06-14-2016, 01:57 PM
If tire has an issur with belts or bubbles, you could see & feel it - get a buddy to sit on the bike & slowly roll it forward. If you pop off bags, you can check the alignment marks on rear axle oval washers & sanity-check alignment with a yardstick against back tire & verify where it points when checking each side - an extra set of hands & eyes always help!
