side stand pad - Victory Forums - Victory Motorcycle Forum
 30Likes
post #1 of 47 (permalink) Old 06-20-2016, 12:59 PM Thread Starter
Default side stand pad
Anyone replace their side stand pad yet ? are those rivets holding it on ?
Roanoke, Virginia (originally from Ithaca, NY)
USMC - Vietnam
2013 Victory Cross Country Tour
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
Dynoed By Nick at 804 MotorSports
1" tank risers
O2 unplugged
1/4 turn ring
JPokerwinski is offline
post #2 of 47 (permalink) Old 06-20-2016, 01:24 PM
Yup, those are rivets and I replaced them with truss head screws and nylock nuts for ease of doing the job the next time.
Tech23 likes this.
post #3 of 47 (permalink) Old 06-20-2016, 01:28 PM Thread Starter
did the nylock nuts stick out too far ? what di d you use about a 1/4-20 ?
USMC - Vietnam
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
1" tank risers
O2 unplugged
1/4 turn ring
post #4 of 47 (permalink) Old 06-20-2016, 01:56 PM
The nut went on the top, so clearance was no problem. I don't recall the size--maybe 10-28. Whatever it was that fit the holes the rivets were in.
post #5 of 47 (permalink) Old 06-20-2016, 02:05 PM
Judge Redd's Avatar
WD's replacement kit comes with screws instead of rivets as well.
2014 Judge(Havasu Red) PC-V - ATS(+4) - RPW Boom Sticks - HOHVM1-DR cams - Torque Tubes (dyno sheet) 1/4 turn throttle - OPT7 LED headlight kit - OEM bags, backrest, and W/S
Judge Redd is offline
post #6 of 47 (permalink) Old 06-20-2016, 02:08 PM Thread Starter
well i just thought of using barrell screws.
USMC - Vietnam
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
1" tank risers
O2 unplugged
1/4 turn ring
post #7 of 47 (permalink) Old 06-20-2016, 03:12 PM
After eyeballing the pad, I see I placed the nuts on the bottom. For screws, I used button w/ allen heads. I would not trust barrel screws.
post #8 of 47 (permalink) Old 06-20-2016, 06:16 PM
my rubber pad went a way 2 years ago.
Keep forgetting to get one. Haven't had a problem with out one
post #9 of 47 (permalink) Old 06-20-2016, 06:59 PM
Its a $7 part...what's the holdup? We can start a fund for you.
post #10 of 47 (permalink) Old 06-20-2016, 07:38 PM
BP6666VR's Avatar
I bought 3 sets of WD replacement rubber and I just installed the last one .... grrrrr they DON'T last very long ... next time I will make my own from better quality rubber ...
EDIT, the barrel screw supplied by WD works very well, just some locktity and it holds ... of course alan key "button" type male and barrel female would work better??
Andre
TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
