Instruction on belt change! - Victory Forums - Victory Motorcycle Forum
 10Likes
post #1 of 17 (permalink) Old 06-24-2016, 12:46 PM Thread Starter
epson390's Avatar
Default Instruction on belt change!
I am going to be replacing my belt this weekend. Anyone know if I need to take the exhaust off? I don't see how you take the guard off the front pulley without removing the pipe.
2014 XC - Pearl White - 16" Ape Hangers, LED Headlight, Lloydz Timing Gear @ +4, SharkHonker Exhaust, PCV, 1/4" Turn Throttle Ring, Hard Lowers, Keyless Ignition, Lloyd's Intake, Klockwerk Shield
epson390 is offline
post #2 of 17 (permalink) Old 06-24-2016, 02:27 PM
You can even remove the rear wheel w/o removing the pipes. Its in your manual. If you don't have a manual, goto the link in Bbob's signature and download one for your bike.
Just curious--Why do you need to change your belt? Over 70K miles? Damage? If not there's no need to.
post #3 of 17 (permalink) Old 06-24-2016, 02:33 PM Thread Starter
epson390's Avatar
Picked up a stone and put a nasty gash in it! Just ordered a new one from Paulie! Looked at removing the old one last night and couldnt seem to figure out how to get it off!
epson390 is offline
post #4 of 17 (permalink) Old 06-24-2016, 02:37 PM Thread Starter
epson390's Avatar
Also just checked the manual from Bbob. Step 4 - Remove cross over pipe. Step 5 - Remove head pipe flange nuts!
epson390 is offline
post #5 of 17 (permalink) Old 06-24-2016, 02:40 PM
Go to the instructions for wheel removal in your manual. Do not touch the rear belt adjusters. Remove the cover that's over the front pulley. Placing the belt should be obvious, but I'm saying more than I know cos I have yet to do this operation. Good luck and keep us posted.
post #6 of 17 (permalink) Old 06-24-2016, 03:33 PM
I agree with epson... and believe the exhaust needs to be removed to pull the pulley cover and remove/replace the belt.
post #7 of 17 (permalink) Old 06-24-2016, 03:43 PM
half_crazy's Avatar
On a cross bike, get new exhaust gaskets... you will need to take the head pipes loose.
Instructions? That's easy.
1. Take old belt off
2. Put new belt on
Suggestion?
Get yourself a service manual.
2006 Victory Kingpin
half_crazy is offline
post #8 of 17 (permalink) Old 06-24-2016, 03:44 PM
Jamming's Avatar
The exhaust has to come off. I discovered that when I blew the seal behind the pulley.
Piece of advice you can choose to take or not, up to you:
When you reassemble the exhaust use silver anti-seize when you reassemble the exhaust system anywhere there's a junction. It'll make it easier the next time. You'll understand the wisdom of this advice when you go to take it apart....heat and a pair of thick gloves is your friend...a heat gun would be perfect to heat the junctions to allow you to slide the pipes out if they've been on a while. That and a dictionary of swear words....
I eat, breathe, live, love and ride motorcycles.
4 wheels move the body, 2 wheels move the soul.
Wiseco fueler, Lloyds timing gear +4, Thrush modded mufflers and LLoyds air filter.
Jamming is offline
post #9 of 17 (permalink) Old 06-24-2016, 05:47 PM
kodiakwood2's Avatar
I have that dictionary.
Gets a lot of use
Eastern Tennessee
Current ride
2018 Goldwing tour
Gone but not forgotten...
Black/Chrome
Ultimate seat and driver backrest, Vic passenger backrest, Custom pinstriping by Dave Davies
Lloyds PTS @+5, Lloyds air filter, PC-V, Miller Mufflers, Lloyds Dyno-Tune,
Lloyds quarter turn throttle ring, Victory HID's, RicZ lay down bracket, Barnett "Stealth" clutch cable
kodiakwood2 is offline
post #10 of 17 (permalink) Old 06-24-2016, 08:06 PM
Definitely get new header pipe gaskets and not OEM ones. Get the ones Lloydz and Witchdoctors sells. They are more compliant.
Motorbikerx and BP6666VR like this.
