Twisted Off Oil Drain Plug - Need Advise - Victory Forums - Victory Motorcycle Forum
 29Likes
post #1 of 81 (permalink) Old 07-15-2016, 07:41 AM Thread Starter
cerobinson's Avatar
Thumbs down Twisted Off Oil Drain Plug - Need Advise
Did a major "F" Up and need direction... (I know, I know, just don't beat me up to hard!!!!)
Changed the oil in my '15 XCT lastnight and used a torque wrench on the drain plug set to the 15 ft/lbs per the manual.. I did use caution and stopped when I thought I felt the click of the wrench.
Found drips this morning on the garage floor, grabbed a normal ratchet figuring I did not get it tight enough and proceed to twist off the head of drain plug..
So, advise on how to fix this. I figured easy outs is really my only choice but looking for someone that has experienced this and how it was fixed.
2015 Cross Country Tour
Two-Tone White Pearl Over Super Steel Grey
Klock Werks Flare Windshield
Victory Tri-Oval Stage 1 Exhaust
Performance Air Filter
EFI re-calibration
Kuryakyn Large ISO-Pegs
Victory Cross Bike Trunk Luggage Rack - Chrome
VicWraps "Blaze" Design
cerobinson is offline
post #2 of 81 (permalink) Old 07-15-2016, 07:47 AM
philmonger's Avatar
With the head busted off, the threaded section might back out easy. See if you can find a section you can tap on with a screwdriver or something and try backing it out.
2011 XR Midnight Cherry, Hard Bags, Vic htd grips & seat, Vic medium Windshield, unlocked speedo, Lloydz Air filter, VFC III, Lloydz ATS +4, Vance & Hines slip ons
1993 Vulcan 1500 (sold)
1981 Yamaha Seca 750 (ridden into oblivion)
1977 Honda 550 (sold)
philmonger is offline
post #3 of 81 (permalink) Old 07-15-2016, 08:29 AM
BP6666VR's Avatar
Can you share a picture of the damaged plug so we can help you better ?
Andre
TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #4 of 81 (permalink) Old 07-15-2016, 08:36 AM
djh3's Avatar
Yea a picture would help us a bunch. If there is something left you may be able to score a slot in remains with a dremel and then back it out with a screwdriver. Left handed drill bits if it comes to having to drill it out. Or I have a set of these "speed out"
2013 XCT added Jan 2015
djh3 is offline
post #5 of 81 (permalink) Old 07-15-2016, 08:56 AM
yup been there done that. what I did was lay the bike on its side ( anchored from the joists). drilled 3 small holes or dimples, if you will. Took a sharp punch, put the point in a dimple and sharply punch counter clockwise. it may take a little while. Be prepared for some oil to run out.
BP6666VR likes this.
Roanoke, Virginia (originally from Ithaca, NY)
USMC - Vietnam
2013 Victory Cross Country Tour
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
Dynoed By Nick at 804 MotorSports
1" tank risers
O2 unplugged
1/4 turn ring
JPokerwinski is offline
post #6 of 81 (permalink) Old 07-15-2016, 09:08 AM
or you can do what others suggested with left hand drill or extractor. The key is to keep the dill centered. start with small drill bits and work your way up to the recommended size for the extractror.
USMC - Vietnam
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
1" tank risers
O2 unplugged
1/4 turn ring
post #7 of 81 (permalink) Old 07-15-2016, 09:13 AM
djh3's Avatar
When I was in the USAF we use to have these small angle cut chisels for screws the head got mangled on. We called them screw chisels, still got one somewhere I think. But yea that works too, sometimes one of those automatic center punches will walk one out doing the same thing. Had a point something like this.
djh3 is offline
post #8 of 81 (permalink) Old 07-15-2016, 10:20 AM
LILMAGS500's Avatar
I don't want to beat up anybody , BUT , either Vic is making a bunch of defective drain plugs or some of you fellas need to have the dealer handle your oil changes .....
LILMAGS500 is offline
post #9 of 81 (permalink) Old 07-15-2016, 11:16 AM
djh3's Avatar
The larger the extractor you can use the less chance you have of breaking that off, and you DONT want to do that.
djh3 is offline
post #10 of 81 (permalink) Old 07-15-2016, 11:26 AM
go out and buy new drill bits and chisel punches. Most are do beat up and dull they'll just give you fits.
Rent a bunch of moving blankets for laying bike on its side.
youtube has some good how to videos.
GOOD LUCK
To anyone reading this get a hex head drain plug to help prevent the stripping
wspollack likes this.
