Front tire recommendation - Victory Forums - Victory Motorcycle Forum
 5Likes
post #1 of 43 (permalink) Old 07-17-2016, 02:10 PM Thread Starter
Default Front tire recommendation
My front tires (E3) are wearing weird , kinda like a ridge down the middle. I am looking to replace them. My rears I replaced last year with another E3. Looking to change.
Also what pressures do people run. ?
Roanoke, Virginia (originally from Ithaca, NY)
USMC - Vietnam
2013 Victory Cross Country Tour
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
Dynoed By Nick at 804 MotorSports
1" tank risers
O2 unplugged
1/4 turn ring
JPokerwinski is offline
post #2 of 43 (permalink) Old 07-17-2016, 02:40 PM
You will get lots of recommendations on tire brand. I like Metzler 888 on my Harley and my wife's VTX. Haven't had to buy tires yet for any of the XCT's. As for pressure, I run 38 psi front/40 psi back regardless of the tire brand.
G'day,
Vinish
G'day,
Vinish
Our patriotic stable:
Red 2012 XCT (my bike for NC)
Vinish is offline
post #3 of 43 (permalink) Old 07-17-2016, 02:48 PM
dennis kirk has the Elite 4 for $209 free shipping. Think it would be good. Don't think my Avon cobra is going to make 15K
40 psi
post #4 of 43 (permalink) Old 07-17-2016, 05:22 PM
vindex1963's Avatar
e3
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #5 of 43 (permalink) Old 07-17-2016, 05:29 PM Thread Starter
40 psi
E4 released ? I may go with that .
LILMAGS500 likes this.
USMC - Vietnam
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
1" tank risers
O2 unplugged
1/4 turn ring
post #6 of 43 (permalink) Old 07-17-2016, 05:30 PM Thread Starter
40 psi
I run my front e3 at 40 psi and people tell me that is why mine worn, I don't buy that
USMC - Vietnam
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
1" tank risers
O2 unplugged
1/4 turn ring
post #7 of 43 (permalink) Old 07-17-2016, 05:58 PM
Motorbikerx's Avatar
That wear pattern would indicate to me you do more straight line Freeway riding than carving through the hills.
My wear indicators generally show on the sides before the middle.
Particularly so on the front tyre, my rear Nightdragon wears the same all round but it's illegal after 5k miles.
You fellas stateside can't complain of tyre wear, if you were Downunder you'd get much less. (must be from riding upside-down)
JPokerwinski and Joe_ like this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 43 (permalink) Old 07-17-2016, 06:18 PM
Default Front tyre
Next front tire/tyre I want to try and run, will be the larger size like KevinX did. My XRs has some slight custom things done to it, so I think it would be one more thing to make people think "what the hell is different about that Victory." Besides I think maybe with a larger front tire on the bike it might make the tire last longer because it would be spreading the load onto a larger rubber contact patch.
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
post #9 of 43 (permalink) Old 07-18-2016, 05:07 AM Thread Starter
The exact opposite. I do more riding in the mountains than highway
USMC - Vietnam
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
1" tank risers
O2 unplugged
1/4 turn ring
post #10 of 43 (permalink) Old 07-18-2016, 05:18 AM
kodiakwood2's Avatar
Jim, my E3's did the same thing, the front wore a ridge down the center, I assumed the harder compound in the center held up while the soft sides disappeared. The back tire cupped so badly on the edges it was unnerving going into corners. I ran them at 40 rear, 38 front. I replaced them at 13,200 miles with Metzler 888's which I run at 42 rear, 41.5 front. So far, so good on the Metz, they stick like glue, are very smooth but only have 4,000 miles on them. Time will tell.
Eastern Tennessee
Current ride
2018 Goldwing tour
Gone but not forgotten...
Black/Chrome
Ultimate seat and driver backrest, Vic passenger backrest, Custom pinstriping by Dave Davies
Lloyds PTS @+5, Lloyds air filter, PC-V, Miller Mufflers, Lloyds Dyno-Tune,
Lloyds quarter turn throttle ring, Victory HID's, RicZ lay down bracket, Barnett "Stealth" clutch cable
kodiakwood2 is offline
