Anyone had this problem - Victory Forums - Victory Motorcycle Forum
 12Likes
post #1 of 16 (permalink) Old 08-06-2016, 03:20 PM Thread Starter
Amboymike's Avatar
Default *Squeak found*
2012 Vic XR
Recently picked up a squeak when hitting bumps.
BUT only after the bike has been ridden for a while.
I cannot reproduce squeak in the garage after the bike has sat over night.
Any ideas?
Found it
The squeak continued to get progressively worse, had dealer tighten/adjust belt also pulled the pivot pin and grease, was still thee.
I jacked it up and took the bottom of the link off and the bottom of shock off. Laid on my back and shined a flashlight up in there.
A gob of tar and chip (rock) had stuck to the top side of the shock bolt/pivot bolt. Next to impossible to see and also real hard to clean. I use a small plastic tube to add to the spry can of cleaner to dissolve the tar then lube up the area. Squeak is gone !!!!!!!
_____________________________________
2012 Crossroads
Amboymike is offline
post #2 of 16 (permalink) Old 08-06-2016, 03:36 PM
Archangel's Avatar
Lowering link?
Michael "Archangel" Sanders
President Cedar Rapids IA
Midwest Regional VP
Roughnecks MC
319-350-9998
[email protected]
half_crazy likes this.
Archangel is offline
post #3 of 16 (permalink) Old 08-06-2016, 04:51 PM
Ride it for awhile and try bouncing up and down while someone listens. Get an idea of where in general it's coming from and you'll solve it faster.
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #4 of 16 (permalink) Old 08-06-2016, 06:04 PM
maybe belt and pulley
when you hear the noise pull in clutch. if it stop its belt
post #5 of 16 (permalink) Old 08-06-2016, 07:36 PM
TNXR's Avatar
I also think it maybe related to the belt and/or pully's. When the bike gets hot the aluminum starts to expand and shrinks back down over night.
2011 Cross Roads Sunset Red
TNXR is offline
post #6 of 16 (permalink) Old 08-07-2016, 11:19 AM
Amboymike
can you give us more information
post #7 of 16 (permalink) Old 08-07-2016, 01:18 PM
Here is a recent thread : https://www.victoryforums.com/36-vict...y-squeaky.html
Read it through. Does it sound like what you are experiencing?
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #8 of 16 (permalink) Old 08-07-2016, 01:26 PM
Travis P's Avatar
My bike was squeaky... Pulled saddlebags pressure washed belt and pulley. Problem solved.
Travis P is offline
post #9 of 16 (permalink) Old 08-07-2016, 09:02 PM Thread Starter
Amboymike's Avatar
yes read all posts about squeaks, my belt squeaks when cold goes away after a few miles.
The is defiantly a metallic squeak but only after the bike is up to temperature, and on a large bump, I called dealer they said sounds like exhaust related due to it being only after bike is up to temp.
I was just throwing it out there to see if anyone had similar issue, my plan is to take long ride on Wednesday the bounce the Sh&* out of it in the garage to narrow it down. I hope.
2012 Crossroads
post #10 of 16 (permalink) Old 08-07-2016, 10:29 PM
Motorbikerx's Avatar
Didn't someone have a bearing failure on the shock link and repair it as well as adding a grease fitting?
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
