Anyone have issues with their XC occasionally slipping out of 2nd? - Victory Forums - Victory Motorcycle Forum
 4Likes
post #1 of 16 (permalink) Old 08-23-2016, 11:58 AM Thread Starter
MIBPreacher's Avatar
Default Anyone have issues with their XC occasionally slipping out of 2nd?
Sometimes when I take off at a light and I shift into 2nd it will slip back into N. its enough to be slightly annoying especially if you are passing someone. My shifter seems alittle wobbly. Thanks!
Currently on a 2011 Victory Cross Country Tour
White/Gray
Chrome accents galore
E2 Enterprises, LLC
Rick Ellis
CEO and Co-President
www.e2notifyme.com
[email protected]
We specialize in custom SMS/SES news deliveries for massive motorcycle events.
MIBPreacher is offline
post #2 of 16 (permalink) Old 08-23-2016, 12:08 PM
LILMAGS500's Avatar
Yes , mine has done that since new especially when accelerating slowly .... You need to shift with authority , no pansy ass shifting on a Vic .
broggyr and Motorbikerx like this.
LILMAGS500 is offline
post #3 of 16 (permalink) Old 08-23-2016, 12:11 PM Thread Starter
Unfortunately, with mine its the exact opposite. Normal out and about cruising I have no issues, but if I need to jump out and pass someone from a red light launch 8 times out of 10, I slip out of 2nd to N.
White/Gray
E2 Enterprises, LLC
Rick Ellis
www.e2notifyme.com
[email protected]
post #4 of 16 (permalink) Old 08-25-2016, 08:00 AM
wspollack's Avatar
All the shifters are wobbly -- you can check them out at a dealer. I do that whenever I go to a dealer or a demo fleet, just to feel better, because mine is on the upper fringes of wobbliness. I've replaced the nylon bushing with OEM ones, and that helped a little. Many folks here have replaced the OEM nylons with metal ones from WitchDoctors, but that often requires sanding the inside or outside of them, to get them to fit and to prevent binding.
Re the slipping issue, do you wait long enough before shifting into 2nd? Because of the easy-neutral-finder mechanism, the bikes won't go into second unless the speed is something like 6mph. But I'd go much higher than that, e.g., at least 15. So, I don't mean to be insulting, but I'd try waiting a bit longer, and also, as stated earlier, shift with authority. Having a heel shifter also helps do that.
Cheers,
Bill P.
wspollack is offline
post #5 of 16 (permalink) Old 08-25-2016, 09:25 AM Thread Starter
Normal shifting 1-10mph i shift from 1st to 2nd.
20-30 i shift from 2nd to 3rd
30-40 i shift from 3rd to 4th
And so on and it never drops a gear.
And no offense taken.
When at a light and I need to pass someone in the left lane and my lane is ending right after the light?
Quick shifting 1-15/20mph, i shift from 1st to 2nd and 8 times out of 10 it will drop to N and i lunge forward wondering what happened...
White/Gray
E2 Enterprises, LLC
Rick Ellis
www.e2notifyme.com
[email protected]
post #6 of 16 (permalink) Old 08-25-2016, 09:49 AM
Motorbikerx's Avatar
Shifting way too early!
Wring it's neck, then bang the next gear in and repeat.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #7 of 16 (permalink) Old 08-25-2016, 04:00 PM
johnnyplano's Avatar
These 106" engines love to rev. They barely come to life under 2,500 RPMs.
Do you bike a favor and don't shift until at least 3,000 RPMs.
Do yourself a favor and don't shift until at least 4,000 RPMs.
Motorbikerx likes this.
2013 Cross Roads Classic
Tri-Oval Stage 1
Lloydz ATS
OEM Tachometer, Windshield Lowers, Driver & Passenger Backrests
Ultimate Midrider Seat
Kuryakyn Sabertooth Tail Lights
Ricz Lay Down License Plate Bracket
28,000 (s)miles and counting...
johnnyplano is offline
post #8 of 16 (permalink) Old 08-25-2016, 04:26 PM
Once you get used to that start taking it to 5000 and you'll really get Motor-vating!
Rev limiter will cut in if you go much further so you can't hurt it.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #9 of 16 (permalink) Old 08-25-2016, 05:15 PM
Tech23's Avatar
You can improve shifting by eliminating the slop in the shift linkage by replacing the factory plastic shift pedal bushings with the brass bushings Witchdoctors offers. You can further decrease excessive shift linkage play by installing an oil drain plug copper washer on the selector shaft between the E clip and the primary cover. All the excessive play you remove translates to more direct/positive movement of the shift drum and shift forks.
Tech23
LILMAGS500 likes this.
Tech23 is offline
post #10 of 16 (permalink) Old 08-25-2016, 09:20 PM
NOEMTZ's Avatar
Possible weak detent spring or loose or worn shifter star.
www.noemtz.com
NOEMTZ is offline
