Sharp, squealing noise coming from low and back. - Victory Forums - Victory Motorcycle Forum
post #1 of 16 (permalink) Old 08-26-2016, 04:25 PM Thread Starter
id-man's Avatar
Default Sharp, squealing noise coming from low and back.
I have heard a really strange squealing noise, three times now, coming from somewhere under my seat and toward the rear of the bike. It doesn't last long enough to locate it's origin, as it only happens for a second, and only when cruising at a steady speed (like 40mph) on smooth pavement, but it's loud enough to let me know it totally not normal. It doesn't happen under acceleration nor when going over bumps, and I have not been able to replicate it intentionally by flexing the suspension or throttle. Since it happens at cruising speed I am probably in 4th gear, though I can't swear to that. It worries me.
The sound is a sharp, high-pitched squeal like something very tight slipping, but only lasts a second and does not recur for several minutes if at all, nor does it occur on every ride. The first time it happened I thought I may have imagined it, but days later it happened twice on the same ride, both times when doing nothing extraordinary, just loping along. Ideas?
Cape Cod, MA
2010 Cross Country "Scrolly"
www.VicWrapz.com
id-man is offline
post #2 of 16 (permalink) Old 08-26-2016, 04:40 PM
LILMAGS500's Avatar
Ha , same thing with my transmission sound , I thought I hallucinated it ... Then it happened again and it was permanent . This is a tough one , id , probably one of two things , suspension , or driveline . A belt chirp perhaps , feel your belt tension when its hot after a ride , if its tighter then a bulls ass , loosen the adjusters the same on both sides and loosen the belt a bit and see if that alleviates it . I would think a suspension related issue would rear it head more frequently on a rougher road , you may want to intentionally hit some rough patches just to check ......
LILMAGS500 is offline
post #3 of 16 (permalink) Old 08-26-2016, 04:40 PM
I'd ask @LILMAGS500 ...he now knows every single noise a Victory is not supposed to make....
post #4 of 16 (permalink) Old 08-26-2016, 04:43 PM
LILMAGS500's Avatar
Ha , I'm already on it !!!
post #5 of 16 (permalink) Old 08-26-2016, 04:43 PM
Okay....This is getting a little weird....I'm out
post #6 of 16 (permalink) Old 08-26-2016, 04:44 PM
LILMAGS500's Avatar
@PaiN Asshole !
post #7 of 16 (permalink) Old 08-26-2016, 04:47 PM Thread Starter
id-man's Avatar
Originally Posted by LILMAGS500 View Post
probably one of two things , suspension , or driveline ...
This bike does have a lowered rear...was it you who had a problem with the heim joint and a bent bolt on a lowering link? I have no idea who's link is on this bike which I bought used a couple thousand miles ago. I would have suspected that kind of fault would produce consistent, repeatable symptoms.
Cape Cod, MA
www.VicWrapz.com
id-man is offline
post #8 of 16 (permalink) Old 08-26-2016, 04:55 PM
LILMAGS500's Avatar
I bought a 2" lowering link and after careful observation , it looked like it was colliding with the air fill hose coming off the shock , so I removed it before even riding the bike . I went to a 1" lowering link but am thinking of going back to the 1 1/2" link . I believe even 2" may be pushing your luck , and could cause other issues .
post #9 of 16 (permalink) Old 08-26-2016, 05:07 PM
could be the wear tab on the rear brake pads. for the heck of it take your bags off your next ride to see if you can hear the chirp better.
Then when you come home and roll into the garage stop the bike with out rolling it backwards. Now look at the belt and see if its in a straight line. If you see a hook in the belt by front pulley your wheel is out of alignment
post #10 of 16 (permalink) Old 08-26-2016, 06:51 PM
LILMAGS500's Avatar
Good advice also , VJ may be on to something ..... Definitely check your breaks .....
