XCT Belt Tension/Alignment - Victory Forums - Victory Motorcycle Forum
 3Likes
post #1 of 14 (permalink) Old 08-27-2016, 06:00 AM Thread Starter
rickster's Avatar
Default XCT Belt Tension/Alignment
Ok I've searched post and I need to do a belt tension/alignment on my 2012 XCT, it will be my first time so I'm a tad nervous. Is there anywhere that shows step by step, is there any tricks to help me. I do think its to tight when under power say 30mph you can here a belt noise, let off the gas it goes away. I would appreciate any help from you to make my first attempt fairly easy. I don't have a lift table but I do have a motorcycle jack to help me out. Thanks much gang
2012 Victory Cross Country Tour Pearl White
"You know your in trouble when the drums stop beating"
rickster is offline
post #2 of 14 (permalink) Old 08-27-2016, 06:37 AM
Motorbikerx's Avatar
At the middle of the lower run of the belt, push up on the belt with one finger as hard as you can without hurting yourself.
How far does the belt push up?
A.when overnight cold
B. after a hard ride
That's with the bike resting on its sidestand.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #3 of 14 (permalink) Old 08-27-2016, 06:59 AM
Sounds like it's tracking to the outside giving you belt squeal/chirp. With back wheel jacked up loosen the axle and adjust the left side (primary side) forward a little the spin the wheel and watch where the belt tracks on the pulley. You want it show a little daylight on both sides of the belt. Once you get there, as long as the belt isn't too tight, in which case you would need to move the entire wheel forward an equal amount on both sides.
Once done, tighten the axle nut, then spin it forward to make sure it didn't move. If all is well spin it backward to see if it tracks over to the left. If it does you're done. Actually even if it doesn't you're done because you only care about the forward motion of the bike but it's supposed to track to the left side when spun backward.
Some of us have to use a wax or lube product on the right outer edge of the belt to keep it quiet. I was able to adjust mine correctly and perfect once but within a thousand miles the chirp was back so I just lube mine with some leather beeswax when it starts chirping again.
BBob is online now
post #4 of 14 (permalink) Old 08-27-2016, 09:12 AM
WeekendRider's Avatar
Step 1: Download the service manual. See: https://www.victoryforums.com/73240-post1.html
Step 2: Start reading at page 2.23.
Step 3: Buy a tension tool. The Motion Pro is fairly inexpensive and works well. Belt Tension Gauge
Not difficult at all.
BBob likes this.
2013 XC Suede Nuclear Sunset
21" Conversion incl. ABS Module, Rear Shock and Forks
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
Lloydz Timing Gear +4
31 Tooth Drive Pulley
Southern Motorworx Tune: 118.08 HP - 114.97 Torque (before 31 tooth drive pulley)
WeekendRider is offline
post #5 of 14 (permalink) Old 08-27-2016, 09:49 AM
The service manual has a very specific step by step process for adjusting both the tension and tracking of the belt. From reading the experiences here on the forums and on my own XCT bikes, a bird chirping/squeaking noise is usually an indication of a belt which is too loose not too tight.
I have alligned belts on two XCT bikes. The first time took me forever but the second time was a piece of cake due to a trick I learned. Loosen the axle nut but not completely. Keep a small amount of tension on this nut so that it takes a fair amount of force to move the axle forward or backward. After every slight turn of the adjustment nuts, get on the side of the bike and make sure the axle is as forward as possible on both sides (that is, make sure both adjustment nuts are up against their stops). Only then should you spin the wheel to examine the tracking of the belt. Much of this may sound cryptic but it will all become clear when you read the service manual instructions for how to adjust belt tension and alignment. Hope this helps.
G'day,
Vinish
BBob likes this.
G'day,
Vinish
Our patriotic stable:
Red 2012 XCT (my bike for NC)
Vinish is online now
post #6 of 14 (permalink) Old 08-27-2016, 11:20 AM
now this video is explain how to. Use the Victory measures you can find it your owner's book
BBob likes this.
post #7 of 14 (permalink) Old 08-27-2016, 12:23 PM
VJ; the belt tension gauge is great for the novice and those who are anal about getting the belt just right by going by the book. I personally can feel what 10 lbs or whatever the book says and I can visualize an inch to an inch and an eighth.
My XC, I believe, has an issue with the pulley design more than how it's adjusted. JMHO, FWIW, YMMV.
BBob is online now
post #8 of 14 (permalink) Old 08-28-2016, 06:26 AM Thread Starter
rickster's Avatar
Is there a way to loosen and torque with out dropping the muffler off and How do you keep the axle against the stops when you retorque the axle nut? Also the manual shows the same adjuster nut for both, is the left for tension and right for tracking or do I have them switched around or backwards. Thanks all
rickster is offline
post #9 of 14 (permalink) Old 08-28-2016, 07:13 AM
Pauljp's Avatar
...is the left for tension and right for tracking or do I have them switched around or backwards. Thanks all
The adjuster on the same side as the belt is to adjust the tension. The other side is to adjust the tracking.
Paul
Gatineau Quebec, Canada
Pauljp is offline
post #10 of 14 (permalink) Old 08-28-2016, 07:19 AM
Pauljp's Avatar
Is there a way to loosen and torque with out dropping the muffler off...
Yes there are other ways.
You could use a crows-foot on the end of your torque wrench so you can reach the nut. Just ensure that it stays at a 90 degree angle to the wrench so it won't change the length of it, thus keeping the ft/lb setting accurate.
You could also remove the bottom bolt from the lowering link so the swingarm drops below the muffler giving you access to the axle nut.
Paul
Pauljp is offline
