Odd Noise - Victory Forums - Victory Motorcycle Forum
 2Likes
post #1 of 14 (permalink) Old 09-02-2016, 04:02 AM Thread Starter
rickster's Avatar
Default Odd Noise
Just had the belt adjusted and tension set but I will get a very odd noise at times. It doesn't make it under power or when off the throttle, but when in between. Like when you just starting to gas or letting off almost like a sweet spot. I can hear it but cant figure out if its from the rear or front end. It doesn't sound like a belt chirp but it does have a rubber squawk kind of noise. Any ideas?? Thanks
2012 Victory Cross Country Tour Pearl White
"You know your in trouble when the drums stop beating"
rickster is offline
post #2 of 14 (permalink) Old 09-02-2016, 04:06 AM Thread Starter
rickster's Avatar
Oh its a 2012 XCT with 21,000 on it will the breaks getting low or a wheel bearing going make a none metal type noise. Thanks
rickster is offline
post #3 of 14 (permalink) Old 09-02-2016, 04:27 AM
LILMAGS500's Avatar
Did the noise start AFTER the belt adjustment or was it there before adjusting ?
LILMAGS500 is offline
post #4 of 14 (permalink) Old 09-02-2016, 05:05 AM
Also try coasting and listening to see if it just gets lower.
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #5 of 14 (permalink) Old 09-02-2016, 06:07 AM
So it doesn't do it when on the gas and it doesn't do it when off the gas........you are confused.
If it sounds like a whirring sound, could be you need to air up your shock as it's rubbing something (look for marks on the belt) or if the bike was recently washed, the belt itself can make a noise against the pulley. I've rubbed candle wax on the ribs of the belt to quiet that down.
Closed minded people suck.
13 Vic CC
05 HD EG
08 HD RG
John R. is offline
post #6 of 14 (permalink) Old 09-02-2016, 10:57 AM
maybe your saddle bag bolts are loose.
you have to be more specific about what sound you're hearing
post #7 of 14 (permalink) Old 09-02-2016, 07:46 PM Thread Starter
rickster's Avatar
It made the noise prior and after the belt adjustment. It sounds something like a belt rubbing noise, I plan on washing the belt real good. Its just odd when it come like there a sweet spot or maybe evn though I'm in the throttle you cant hear it as well as say 30 or 40. its an odd one but at times it sounds like the front end? maybe my front tire is getting to the point it needs replacing??
rickster is offline
post #8 of 14 (permalink) Old 09-03-2016, 05:42 AM Thread Starter
rickster's Avatar
it also didn't make that noise until after I just had a rear tire put on so now I'm wondering if might be there??
rickster is offline
post #9 of 14 (permalink) Old 09-03-2016, 06:55 AM
LILMAGS500's Avatar
I'm willing to bet your belt is too tight , it may only be in certain spots on the pulley . (pulleys are not perfectly round , so you have tighter tension and more loose tension at any given time) When your belt is too tight it can make all kinds of strange sounds , especially when coasting at lower speeds , being under power helps mask the sound so it is less noticeable ....
Luciferiad likes this.
post #10 of 14 (permalink) Old 09-03-2016, 10:04 AM
Luciferiad's Avatar
Also make sure your wheel alignment is correct, and in doing so you can eyeball the runout on pulley. Check for irregularities.
Mine:
2011 Cross Roads, crimson red
Hers
2015 Vegas 8-Ball
Luciferiad is offline
