HELP!!!!!No High Beams nor High Beam dash indicator - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By Triride44
post #1 of 8 (permalink) Old 09-10-2016, 12:41 AM Thread Starter
Wrisperj's Avatar
Default HELP!!!!!No High Beams nor High Beam dash indicator
I have a 2015 XCT and recently noticed that I didn't have high beans nor high bean dash indicator. What could be the culprit?
Fort Stewart, GA
2015 XCT
Wrisperj is offline
post #2 of 8 (permalink) Old 09-10-2016, 04:31 AM
LILMAGS500's Avatar
The high beam bulb is burnt out ?
LILMAGS500 is offline
post #3 of 8 (permalink) Old 09-10-2016, 05:26 AM Thread Starter
Wrisperj's Avatar
Bulb is fine. Replaced the bulb and results are the same. OBTW I have HID low beam and OEM high if that helps.
Fort Stewart, GA
2015 XCT
Wrisperj is offline
post #4 of 8 (permalink) Old 09-10-2016, 05:53 AM
Triride44's Avatar
Default High Beam
Check for power to and from the switch for high beam. Also check the ground for the High Beam bulb.
Black '11 XC, Vance & Hines Hi-Flow muflers,
Lloydz Air Filter & ATS (+4)
Dobeck AFR+ (Gen4)
"People Should Not Be Afraid of Their Governments
Governments Should Be Afraid of Their people".
V for Vendetta.
Triride44 is offline
post #5 of 8 (permalink) Old 09-10-2016, 06:29 AM
doobliss's Avatar
How's about the fuse box? Any blown ones in there?
'15 Gloss Titanium XC.
WOLO Low Tone Disc Horn
Tri-Oval Slip Ons
Black LED Headlight
Kingpin Metal Fork Guards
Ricz Lay Down Plate
Lloydz Timing Wheel & Throttle Ring
Shinhopples Grip Covers
12" Long Ride Shield
Bad Ace Billet Fork Mounted Air Deflector
Ness Signals; Amber front, Red rear
http://www.pure-gas.org/
"I leave the BUG CARNAGE on my screen , it adds character!"-LILMAGS500
doobliss is offline
post #6 of 8 (permalink) Old 09-10-2016, 06:33 AM Thread Starter
Wrisperj's Avatar
Hadn't checked. Was told low and high were on same fuse.
Fort Stewart, GA
2015 XCT
Wrisperj is offline
post #7 of 8 (permalink) Old 09-10-2016, 07:03 AM
Triride44's Avatar
Default Not Fuse
Because the low beam is working, the fuse & relay are good. The left handlebar switch has power in on pin 1 from the relay and out to the head light on pins 2 & 3. Low beam on pin 2, and High beam on pin 3.
Dobeck AFR+ (Gen4)
V for Vendetta.
post #8 of 8 (permalink) Old 09-10-2016, 07:25 AM
Triride44's Avatar
Default Wiring bug
The fact that the High Beam indicator on the dash doesn't come on, and the low beam works, tells me the switch or wiring is the problem. Electrical wiring problems are sometimes hard to locate. Take your time and think about each step and with some diligence you'll figure it out. Once you find it, should be a easy fix.
BenD likes this.
Dobeck AFR+ (Gen4)
V for Vendetta.
