Noise Help - Victory Forums - Victory Motorcycle Forum
 3Likes
  • 1 Post By Vinish
  • 1 Post By sgtfixit
  • 1 Post By AzRocket
post #1 of 8 (permalink) Old 09-16-2016, 10:49 PM Thread Starter
AzRocket's Avatar
Default Noise Help
I know it's hard for everyone to describe a sound and even harder to help diagnose, but here goes. The best description I can give is a chirp/squeal. I can't tell if it's coming from behind or under. When my wife was riding with me, she couldn't tell where at either. I know it ONLY does it while accelerating. If I pull the clutch in and rev, it won't do it. When I let off the throttle it will stop (if it was doing it). I just started hearing it a few weeks ago. It runs fine, I just hear the noise. I have about 9500 miles on it, 2013 XC with Stage 1 kit, purchased used a few months ago. I initially thought it was something with the Exhaust because if when I hear it. But now I think it might be belt, but not sure since I don't know what that sounds like. Any thoughts?
AzRocket is offline
post #2 of 8 (permalink) Old 09-17-2016, 07:24 AM
Sounds like a belt that is too loose and/or not properly aligned/centered. There is a process for adjusting the tension and alignment in the service manual which should be followed. When following this procedure, keep the axle nut slightly tight so that the tire can be moved by hand but takes some effort and make sure to push the tire back in its slots on both sides firmly prior to performing the alignment test after each adjustment of the axle/wheel alignment bolts.
G'day,
Vinish
LILMAGS500 likes this.
G'day,
Vinish
Our patriotic stable:
Red 2012 XCT (my bike for NC)
Vinish is offline
post #3 of 8 (permalink) Old 09-17-2016, 07:32 AM
LILMAGS500's Avatar
Belt tension / alignment . Should be an easy fix .
LILMAGS500 is offline
post #4 of 8 (permalink) Old 09-17-2016, 07:40 AM Thread Starter
AzRocket's Avatar
Thanks guys
AzRocket is offline
post #5 of 8 (permalink) Old 09-17-2016, 07:46 AM
I'll pile on and say belt alignment and/or tension
post #6 of 8 (permalink) Old 09-17-2016, 11:25 AM
sgtfixit's Avatar
Default obvious first
just thinking out loud...before anything else...have you cleaned the belt I had the same symptoms you described. could not align or tension the belt without making more noise. A buddy suggested simply cleaning the belt with a damp rag and dish soap. I also hit the ribs with a brush. No more chirp on acceleration!
Yes it is easy to align and tension the belt, but it may be even easier than that.
Good luck
RICZ likes this.
MSgt Ret. Security Forces USAF/Santa Maria, CA
2011 Victory Cross Country (Imp Blue)
-Mods-Vic Military Salute Wedge Covers/Madstad with stock shield/Floor Board Hwy Pegs/2012 Hard Lowers/Hard Bag Bars/adj. pass. foot rests/+2 SRVT Pull Back Bars/Mirror extenders/LED driving lights/WOLO horn/RicZ laid down plate bracket/Kuryakyn Brake Pedal/Signal Dynamics headlight modulator/Custom Dynamics Brake light Strobe/LED rear plate/1/4 turn throttle ring/Lloydz timing wheel +4
sgtfixit is offline
post #7 of 8 (permalink) Old 09-17-2016, 11:54 AM
download a manual to your computer. All CC's are the same for pretty much everything. Am sure its the belt
https://www.mediafire.com/folder/aoq...ictory_Manuals
post #8 of 8 (permalink) Old 09-17-2016, 09:32 PM Thread Starter
AzRocket's Avatar
I gave it a quick clean last night, and during my ride today, the sound was either gone or hardly noticeable. I'll know more when I get home and ride without a helmet with less traffic. Plus, I'll be able to check the deflection on it.
sgtfixit likes this.
AzRocket is offline
