Victory Heated Grips - Victory Forums - Victory Motorcycle Forum
 9Likes
post #1 of 37 (permalink) Old 10-08-2016, 09:01 AM Thread Starter
LILMAGS500's Avatar
Default Victory Heated Grips
Hey Guys , with my new apes I lost my heat demons , I was thinking of going Victory heated grips as I do extensive cold weather riding . Anyone able to give me a quick review of performance / heat output on these ? Thank you .
LILMAGS500 is offline
post #2 of 37 (permalink) Old 10-08-2016, 09:20 AM Thread Starter
LILMAGS500's Avatar
I think these are identical to the factory installed heated grips standard on the XCT .....
post #3 of 37 (permalink) Old 10-08-2016, 09:20 AM
Travis P's Avatar
Why did you lose your heat demons?
Travis P is offline
post #4 of 37 (permalink) Old 10-08-2016, 09:27 AM Thread Starter
LILMAGS500's Avatar
Once installed they are pretty much married to the bars .... Plus the switch is bar mounted and wont fit the new bars .... I fear trying to fish the wires through the apes from one side to the other may be impossible anyway .
post #5 of 37 (permalink) Old 10-08-2016, 09:30 AM Thread Starter
LILMAGS500's Avatar
I think the Victory ones have external wiring and come with a switch that goes right into the dash , giving a professional look . I just wonder if they throw good heat , they should for 200.00 !!!
post #6 of 37 (permalink) Old 10-08-2016, 09:51 AM
wspollack's Avatar
Yeah, I've used mine on my XCT. They put out decent heat -- mostly use them on the lower setting, because the higher setting is generally too hot.
That being said:
- I'm old and wimpy, so I don't do a ton of really cold weather riding.
- There may be better values out there, from other vendors -- the stock XCT ones are the first heated grips I've had (I've used heated gloves before), so I don't have any comparison experience.
SALTY likes this.
Cheers,
Bill P.
wspollack is offline
post #7 of 37 (permalink) Old 10-08-2016, 10:02 AM
The factory heated grips have high low settings and do produce good heat.
Vic all so has a switch to mount in your blank hole for on off.
There is Avon grips that produce good heat all so.
I would think with a bent coat hanger with a good hook on the end you could pull the Demons out.
Your #1 Source for US Made, Custom Victory Motorcycle Parts
post #8 of 37 (permalink) Old 10-08-2016, 10:41 AM
wspollack's Avatar
Here are the heated-grip and heated-grip-overlay reviews from webBikeWorld, my main go-to site for reviews:
2005: Hot Grips: Hot Grips Heated Grips Review - webBikeWorld
2005: Oxford Hot Hands
2008: Oxford Hot Grips
2009: Koso Apollo Heated Grips
Notes:
- The webBikeWorld store on Amazon has a larger collection of grips and heated wraps, i.e., beyond those four reviews. See The wBW Amazon.com Store! - Heated Grips
- All of these are cheaper than the Vic grips.
- The dates on the left are the review dates, but some of these have user comments that are more recent.
- The Koso review is for 7/8" grips, but it mentions that they also come in 1" version.
- The Koso grips look really interesting, and now I'm considering buying them for my Burgman.
Cheers,
Bill P.
post #9 of 37 (permalink) Old 10-08-2016, 11:22 AM Thread Starter
LILMAGS500's Avatar
Thanks guys , if the Vic ones put out good heat I may go with those and a set of the WD bar ends in the link VJ put up .
post #10 of 37 (permalink) Old 10-08-2016, 11:53 AM Thread Starter
LILMAGS500's Avatar
Does anyone have the Vic heated grips and thinks they suck ?
