audio system updated with RF 300x4 - Victory Forums - Victory Motorcycle Forum
 3Likes
  • 1 Post By sebas-ARG
  • 1 Post By MaddogUSMC
post #1 of 9 (permalink) Old 12-11-2016, 09:39 PM Thread Starter
sebas-ARG's Avatar
Default audio system updated with RF 300x4
i need help guys,,
i have a XC and i went from rockford fosgate 2 channel with 2 front speakers alpine ( sound good but i wanted more) then i installed the RF 4 CHANNELS with 2 polk 6.5 in front and 6.9 in saddlebags, for the first 5 minutes sound awesome then it shut off. but display screen and controls still working fine, i rechecked fuse from battery and wires on the fairing and there is nothing wrong, except there is no sound.. i reinstall the previous RFx2( which was working fine) and still no sound.. i change different station on the radio , and shows everything but no sound..
thanks for ur help....................
sebas-ARG is offline
post #2 of 9 (permalink) Old 12-12-2016, 03:10 AM
MaddogUSMC's Avatar
Did you try to just hook up the speakers without the amp? If you do and the sound works, then you know there's a problem with the amp.
2015 Victory Cross Country Tour 7/30/16 - 12/31/16
Lloydz ATS +4 and O2's disabled
Ultimate Seat and Driver Backrest
Alpine SPR-50 for front speakers and Polk Audio DB522 for the trunk speakers
Kuryakyn LED speaker grills
Michelin Commander II front and rear tires
Wolo Bad Boy air horn
Fusion LED kit for the whole bike
Tinted Klock Werks Flare (for winter riding due to fogging up)
Jax, FL
MaddogUSMC is offline
post #3 of 9 (permalink) Old 12-12-2016, 03:58 PM Thread Starter
sebas-ARG's Avatar
Thanks, i fixed the problem.. Thanks for your guidance. maddog
post #4 of 9 (permalink) Old 12-12-2016, 05:25 PM
What was the issue...(may help someone avoid it in the future)
Cobra206 is offline
post #5 of 9 (permalink) Old 12-13-2016, 02:13 AM
MaddogUSMC's Avatar
What did you do to fix it? Glad I could be of some help.
Jax, FL
post #6 of 9 (permalink) Old 12-13-2016, 09:57 AM Thread Starter
sebas-ARG's Avatar
The issue was the amp burn the power cable right before the fuse holder on the battery. Didnt see it before because it has a cover, i just. Checked the fuse.
Sound weird., but i was just that ..
Now the system sound awesome. I firmly recommends polks speakers and RFx4.. Thanks guys
MaddogUSMC likes this.
post #7 of 9 (permalink) Old 12-13-2016, 11:08 PM
MaddogUSMC's Avatar
What caused that? Something had to cause it to draw enough amperage to cause that problem. May want to check into that before your bike turns into a blazing inferno as you are riding down the road. I tell my mechanics the same thing. Something caused the problem in the first place. Btw....look at my signature! I have Polk Audio speakers in the back.
Sent from my SAMSUNG-SM-G870A using Tapatalk
sebas-ARG likes this.
Jax, FL
post #8 of 9 (permalink) Old 12-14-2016, 09:03 AM Thread Starter
sebas-ARG's Avatar
I DID MY RESEARCH AND WHAT HAPPENED WAS, THAT THE GUY WHO INSTALLED MY FIRST AUDIO SYSTEM PUT A POWER CABLE TO BATTERY OF (8GA) , THEN WHEN I INSTALLED MY NEW RF300x4 I DIDNT CHANGED THAT POWER CABLE ( which is to small for the new RF300X4) it burn and corbonized the power cable) I PUT A NEW ONE FOR 500W AMP AND EVERYTHING IS NORMAL NOW... THANKS
post #9 of 9 (permalink) Old 12-14-2016, 10:22 AM
MaddogUSMC's Avatar
Good deal! Enjoy it!
Jax, FL
