Battery advice/opinions - Victory Forums - Victory Motorcycle Forum
 10Likes
post #1 of 32 (permalink) Old 12-13-2016, 10:29 AM Thread Starter
TNXR's Avatar
Default Battery advice/opinions
Just went out to the garage and got geared up to ride and wouldn't you know it the bike barely turned over (been on a battery tender). I got it started and letting it idle right now but I think I am in need of a new battery. My bike is a Jan 2011 build so I assume the battery is even older so it is at least 6 years old. Called out to my local Vic/Indian dealer and they want $145 for a Yuasa/Polaris battery but I just saw where I can get the same battery model number without the Polaris logo on it for $88 on Amazon and is shipped with the acid separate. Anybody gone this route or gone with a battery from and autozone or other auto parts stores?
2011 Cross Roads Sunset Red
TNXR is offline
post #2 of 32 (permalink) Old 12-13-2016, 10:40 AM
With so few manufacturers of batteries it is one product that highlights the phrase "You get what you pay for". As for the Vic one, vehicle builders with profit as their main concern will go with whatever gives them the best return. I won't go into a long explanation here but simply look at the specs, not the name.
Then think about the worst place in your travels that you'd want to get stranded because you cheaped out on one of the most important parts of the vehicle. That's where it will happen.
No matter what you buy, always go for the best (not always the most expensive) you can afford at the time.
PS. The one directly from the Vic stealer certainly won't be the best choice financially. The one from Amazon needs you to confirm the source and product. Local suppliers will have one that's not much more expensive.
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #3 of 32 (permalink) Old 12-13-2016, 10:42 AM
Bullypack3's Avatar
https://www.victoryforums.com/36-vict...endations.html
Here's a discussion on battery's
2013 Vegas 8 Ball
ATS +4
Ness Intake
Miller Mufflers
pcV
Ness Fly Bars
And a nagging itch to add more
2016 CCT
Miller Mufflers
Lloydz ATS +4
Long Ride Shields Screen
Bullypack3 is offline
post #4 of 32 (permalink) Old 12-13-2016, 10:48 AM
Luciferiad's Avatar
I picked up a store-labeled Deka at a local ranch store for about $85. 310 cca, sealed, charged, and ready to go. So far so good.
Mine:
2011 Cross Roads, crimson red
Hers
2015 Vegas 8-Ball
Luciferiad is offline
post #5 of 32 (permalink) Old 12-13-2016, 10:55 AM
HowardGNelson's Avatar
I used to work at a dealer that sells victory. all the batteries (including the ones shipped with your bike) come with the acid separate.
2012 XCT Sunset Red - D&D's, Lloydz filter, ATS +4, Clearwater Krista's, Fusion LED kit, Rusty Jones single din, Sony head unit, PCV, BAB Tank Lift, BAB 1/4 Turn, Kenwood 400x4 amp, Soundstream 1000x4 amp, Focal 6.5s, DS18 tweeters, Polk Audio DSi5.25s, Rick Fairless mini apes
RIP my 2010 Victory XC-Skull bike (Totaled 10/21/16)
07 Jackpot Premium - white w/ flames(SOLD)
**Stop saying "how dumb can you be", people seem to be taking it as a challenge**
HowardGNelson is offline
post #6 of 32 (permalink) Old 12-13-2016, 10:59 AM
Judge Redd's Avatar
The duracell from Batteries + is outstanding. Rated identical to the OEM- about 310 CCA.
However, the rep took the one I grabbed off the shelf, clamped on his bench tester, and the damn thing showed over 500 CCA. After installation- the bike has on occasion has sat for 3 weeks over the winter months. Showed no signs of discharge. Hooked up my trickle charger anyway- green light in less than 10 minutes. Awesome battery thus far.
BBob and RICZ like this.
2014 Judge(Havasu Red) PC-V - ATS(+4) - RPW Boom Sticks - HOHVM1-DR cams - Torque Tubes (dyno sheet) 1/4 turn throttle - OPT7 LED headlight kit - OEM bags, backrest, and W/S
Judge Redd is offline
post #7 of 32 (permalink) Old 12-13-2016, 11:01 AM
WeekendRider's Avatar
For the record, Yuasa makes a very good battery.
I would suggest you call around - call the local powersports dealers/shops - and give them the Yuasa part number. There aren't that many different size motorcycle batteries and if they carry Yuasa they will most likely have the size you are looking for.
My local Yamaha dealer always has had the best prices on batteries and I've bought them there for non-Yamaha bikes.
They will still be a little more expensive than mail-order but you get the battery right away, acid already added and battery fully charged, and you have some place to return it to if for any reason that battery is bad.
2013 XC Suede Nuclear Sunset
21" Conversion incl. ABS Module, Rear Shock and Forks
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
Lloydz Timing Gear +4
31 Tooth Drive Pulley
Southern Motorworx Tune: 118.08 HP - 114.97 Torque (before 31 tooth drive pulley)
WeekendRider is offline
post #8 of 32 (permalink) Old 12-13-2016, 11:35 AM
TNXR, think about this: A relatively small battery has to start an engine larger than some cars have and when its cold out, the oil is thick thus providing even more resistance. My 2010 XR still has its original battery and over 30K miles with lots of starts. I do two things that make life easier for the battery: 1. 5W-40 Rotella T-6 and 2. About an hour before starting, I place a heater with a fan in it near the engine to warm the oil, battery (which is down on power when cold) and the engine. It usually fires up the first time, even after sitting over a month. So you battery may be just fine.
RICZ is online now
post #9 of 32 (permalink) Old 12-13-2016, 11:41 AM
Never Never get acid batteries. They don't last.
Always get a gel filled battery. Yuasa is a great battery
post #10 of 32 (permalink) Old 12-13-2016, 11:43 AM
What's your thoughts about AGM batteries?
RICZ is online now
