Steering Head Bearing Upgrade - Victory Forums - Victory Motorcycle Forum
 47Likes
post #1 of 131 (permalink) Old 01-03-2017, 11:43 PM Thread Starter
Default Steering Head Bearing Upgrade
I could not find on line anything pertaining to upgrading/replacing Cross bike steering head bearings, so I will document the procedure with words and photos as I progress.
Inasmuch as I am also changing the fork oil, I have removed the entire front end and won't document that cuz there are many videos already out there.
There's some good news here for XR owners: the top triple tree can be lifted off the stem and set aside, exposing the stem and the top bearing. This is contrary to the manual, which calls for disconnecting all cables, wires and hoses. A big hour generator for shops. XC owners; eat your hearts out!
Top photo: With top tree aside, just loosen the round adjusting nut and catch the lower tree as it slides out.
Middle photo: Lower stem bearing is a tapered roller, but the top is a sealed ball type which I'll attempt to replace with a thicker roller. Will it work? Hmm.
Bottom photo: Yes you can do it without disconnecting cables and hoses. Now don't you wish you bought a XR?
RICZ is online now
post #2 of 131 (permalink) Old 01-04-2017, 11:14 AM
Well Ric, we now know what your PMS winter project is to keep you busy... :^) Good luck.
RICZ and broggyr like this.
2012 Cross Country Tour - VroomHilda
Dobeck EJK Gen3 Fuel Tuner
Tri Flo Ovals
Vic K&N knock off Air filter
Lloyds Timing Wheel +2
Relocated Air Shock fill hose
WD SkidPlate reinforced
Hyperlites
Garmin GPS
Existential Secular Humorist with warrior Buddhist leanings
*Rider/Owner continuous since 1973 - 877,000+ miles USMC R
SemperVee is offline
post #3 of 131 (permalink) Old 01-04-2017, 11:35 AM Thread Starter
I'm having more fun than an old fart retiree ought to.
vindex1963 and broggyr like this.
RICZ is online now
post #4 of 131 (permalink) Old 01-04-2017, 12:12 PM
now the big challenge will be getting the bottom bearing off.
A local shop might have the tool to take it off and press a new one on.
Grease the hell out of the bearing
post #5 of 131 (permalink) Old 01-04-2017, 12:32 PM Thread Starter
A big 10-4 about the grease VJ. If the lower brg won't tap out easily, I have a puller that should do the trick. There's a gap of about 1/8" between the brg and the bore and the fingers of the puller should be able to get a grip in there. There's a link to it below. I'll be talking that today and taking photos. Stand by.
3-Jaw Pilot Bearing Puller
RICZ is online now
post #6 of 131 (permalink) Old 01-04-2017, 01:30 PM
541RF's Avatar
RICZ,
I got the old Fart down, but can't seem to get the retired part yet. Have fun on the repair.
DirtyDan and id-man like this.
541RF
2004 Arlen Ness Signature Series Vegas
Black-Cherry Fade
Stage one dealer kit installed
Bags, tour seat with backrest and rack
Southern, OR.
541RF is offline
post #7 of 131 (permalink) Old 01-04-2017, 02:41 PM
I have changed or helped change probably more than 50 steering stem bearings on Honda VTX1300's. They have notoriously bad steering stem bearings and groups of VTX1300 riders gather for tech sessions at which help is provided to the owners to do maintenance items like these bearings, valve adjustments, etc. The steering stem on the Victory XR looks very similar to that of the VTX1300 so perhaps the easy method I use to remove old and install new bearings will be helpful.
Removal:
1) Using a 1/2" wide cold chisel held perpendicular to the stem and a 3 lb sledge, drive the "point" of the chisel into the gap between the bearing and the metal of the stem. The goal here is to drive the bearing upwards about 1/8". This may take several whacks to get it moved that far.
2) Place one end of a 1/4 to 5/16" diameter x ~12" long steel rod against the bottom of the bearing in the 1/8" gap that was formed in step #1. Angle this rod as close to parallel to the stem as you can while still getting a "bite" on the bearing. Note that the rod will be coming up at the bearing from below the bottom triple tree brace. Whack the other end of the rod with the 3 lb sledge thus driving the bearing upwards. Continue this whacking until the old bearing has moved about 1" at which point it will be free of the larger shaft diameter portion and come off easily.
Installation:
1) Put the dust cap on the shaft if there is one.
2) Grease the bearing
3) Place the bearing onto the shaft
4) Find or make some small donut shaped (sort of hollow cylinder shaped) steel object that will just barely fit loosely on the larger diameter portion of the stem/shaft and will press on the INNER race portion of the new bearing. For the VTX1300, we use the old bearing race with a groove/notch cut through it so that it will not bind on the shaft. Perhaps there is a part of the old bearing on the victory that can be removed and used for this purpose. Place this object onto the new bearing on the shaft.
5) Place a pipe nipple of 1.25" NPS x 12" long onto the shaft. This presses on the "object" in #4.
6) Grip a 4" x 4" x 1/4" steel plate firmly with vice grips and place this over top of the pipe nipple
7) Using the 3 lb sledge, bang on the steel plate which hits the pipe nipple which hits the "object" which hits the new bearing driving it into place. You can usually tell from the sound of the sledge hit when the new race has been driven into place.
Hope this helps. It is an easy-peasy operation on the VTX1300 once you get the front end off the bike and once you have all the right homemade tools.
G'day,
Vinish
G'day,
Vinish
Our patriotic stable:
Red 2012 XCT (my bike for NC)
Vinish is offline
post #8 of 131 (permalink) Old 01-04-2017, 03:47 PM Thread Starter
I appreciate your suggestions Vinish and will be applying some, but not all because I refuse to pound on one side of an internal bearing, I prefer to tap. If tapping doesn't budge it, I'll use a puller. The repair biz I had involved rebuilding hubs very similar steering heads and I learned that if you pound on one side of a stuck bearing, the metal around it gets deformed as the bearing gets angled against it.
I do have the old top bearing removed and it required the puller. However, the puller did an excellent job. Gonna attack the lower one now. Stand by.
RICZ is online now
post #9 of 131 (permalink) Old 01-04-2017, 04:03 PM
p.hunt's Avatar
You should probably do your wheel bearings while your at it! And do a write up for me. Haha
Chattanooga Mark likes this.
2012 Vision - in process of converting to Cross Country rear end and bags
Lloyd's -Filter-Timing wheel-Adjustable Intake-Throttle ring
PCV5
Home built 2 into 1 pipe with dummy pipe on left looks stock
p.hunt is offline
post #10 of 131 (permalink) Old 01-04-2017, 04:20 PM
541RF's Avatar
RicZ, Use a heat gun on the steering head before removal and later install. We do this on aluminum wheels and the races almost fall out.
541RF
Black-Cherry Fade
Southern, OR.
541RF is offline
