Abs light - Victory Forums - Victory Motorcycle Forum
 2Likes
  • 1 Post By JPokerwinski
  • 1 Post By vindex1963
post #1 of 6 (permalink) Old 03-09-2017, 07:20 AM Thread Starter
rainman123's Avatar
Default Abs light
Going to work this morning my abs light came on after it got light enough to see I visually checked it and couldn't see anything wrong any suggestions
Thanks it's on a 12 xr
2012 crossroad
08 r3t traded for xr
06 rocket classic totaled
98 t-bird traded for rocket
73 sportster sold
72 honda 350 long gone
06 rocket3 classic
rainman123 is offline
post #2 of 6 (permalink) Old 03-09-2017, 09:32 AM
BP6666VR's Avatar
There is a whole Thread about this, interesting stuff and ideas... But no luck for me, so i ordered new ones
Andre
TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 6 (permalink) Old 03-09-2017, 09:54 AM
I think one of the most common issues is dirt on the sensor and/or the gap between the sensor and wheel. Check both. My gap was on the outside edge of the spec and it came on like that. I adjusted it and never saw the problem again.
visionjohnny likes this.
Roanoke, Virginia (originally from Ithaca, NY)
USMC - Vietnam
2013 Victory Cross Country Tour
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
Dynoed By Nick at 804 MotorSports
1" tank risers
O2 unplugged
1/4 turn ring
JPokerwinski is offline
post #4 of 6 (permalink) Old 03-09-2017, 10:02 AM
vindex1963's Avatar
Friend of mine had that happen in his Vision, had a loose battery cable the light never came back on.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #5 of 6 (permalink) Old 03-09-2017, 02:47 PM
Honda East Toledo's Avatar
Clean, check gap, clean again, check gap, replace.
(419) 891-1230 ext 235
(877)-437-1631
http://www.hondaeasttoledo.com
http://www.hondaeastsuperstore.com
Like us on Facebook
Follow us on Twitter!
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
Honda East Toledo is offline
post #6 of 6 (permalink) Old 03-10-2017, 08:06 AM
NOEMTZ's Avatar
9 out of 10 times, its a bad sensor.
www.noemtz.com
NOEMTZ is offline
