Extreme 6 Speaker Fairing Audio and Amp Kit 2880766 Install Issue - Victory Forums - Victory Motorcycle Forum
 13Likes
post #1 of 28 (permalink) Old 03-12-2017, 04:51 PM Thread Starter
kezzy39's Avatar
Default Extreme 6 Speaker Fairing Audio and Amp Kit 2880766 Install Issue
Bought this Victory kit and installed it yesterday. All went well until the last step. "Locate constant power from the right hand side aluminum fairing frame and connect Power in". The 2 wires in question from the auxiliary harness supplied have a large male blade end and a small male blade end. Found the wire on the factory harness marked power and plugged the large male blade end into it. No other connectors on the right hand side to plug the small male blade end in. Has anyone installed this Victory kit? What have I or Victory missed to finish this install?
Sent from my iPad using Tapatalk
2014 Cross Country. Stage 1 Exhaust Upgrade. LED Headlight. Keyless Ignition. Victory Chrome Bling.Winnipeg Manitoba Canada.
kezzy39 is offline
post #2 of 28 (permalink) Old 03-12-2017, 05:29 PM
MaddogUSMC's Avatar
One is probably your hot and the other one probably is the return. That is my guess
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Victory Cross Country Tour 7/30/16 - 12/31/16
Lloydz ATS +4 and O2's disabled
Ultimate Seat and Driver Backrest
Alpine SPR-50 for front speakers and Polk Audio DB522 for the trunk speakers
Kuryakyn LED speaker grills
Michelin Commander II front and rear tires
Wolo Bad Boy air horn
Fusion LED kit for the whole bike
Tinted Klock Werks Flare (for winter riding due to fogging up)
Jax, FL
MaddogUSMC is offline
post #3 of 28 (permalink) Old 03-12-2017, 05:51 PM
LILMAGS500's Avatar
You piggy back them to your power outlet , if you already installed the volume , you will need to remove it to access the plug ... They dont tell you that ......
SkInM4N likes this.
LILMAGS500 is offline
post #4 of 28 (permalink) Old 03-12-2017, 05:53 PM
LILMAGS500's Avatar
I have the original factory instructions if you want me to email them to you .
post #5 of 28 (permalink) Old 03-12-2017, 05:59 PM Thread Starter
kezzy39's Avatar
That would be great. Thanks. [email protected]
kezzy39 is offline
post #6 of 28 (permalink) Old 03-12-2017, 06:02 PM Thread Starter
kezzy39's Avatar
Do I piggyback both flat blade male connectors to the power outlet?
kezzy39 is offline
post #7 of 28 (permalink) Old 03-12-2017, 06:10 PM
LILMAGS500's Avatar
YES you do ......
kezzy39 likes this.
post #8 of 28 (permalink) Old 03-12-2017, 06:13 PM Thread Starter
kezzy39's Avatar
YES you do ......
Thanks
kezzy39 is offline
post #9 of 28 (permalink) Old 08-03-2017, 05:08 PM
webchad's Avatar
Default no instructions
I just picked up a extreme audio 6 speaker kit at a steal from an online vendor. sadly, it didn't come with any install paperwork, well that's not entirely true. i got paperwork for installation of a heel toe shifter kit. could someone please scan and post or email their instructions if anyone still has them?
webchad is offline
post #10 of 28 (permalink) Old 08-03-2017, 06:51 PM Thread Starter
kezzy39's Avatar
I gave up on the kit and returned it. Instructions were good until the end.
kezzy39 is offline
