Problem on the Road - NOW - Victory Forums - Victory Motorcycle Forum
 29Likes
post #1 of 31 (permalink) Old 03-21-2017, 06:56 PM Thread Starter
arkiebiker's Avatar
Default Problem on the Road - NOW
OK...maybe a problem or not. I'm in the middle of a 2500 mile ride with about 900 miles behind me so far....I'm here in Cheraw, SC and heading to Chesapeake, VA tomorrow morning.
Here's the deal. Bike is running great...really it is. But on my next to last gas stop, the would turn over fine, and even sputter but would not run...after two or three attempts...it started...acted fine and I rode another 200 miles today. When I get to the hotel (where I'm at now), I was gonna go grab something to eat...hopped on and same thing...except this time it took about 5-6 attempts, but same symptoms as before. Turns over, acts like its not getting gas and then eventually starts. Once it started...it was fine again.
When I went back out to the bike with my food...I was afraid it would not start at all. SO THIS TIME...I turned the key on, then I turned the ON/OFF switch on (which starts the fuel pump)...and I let it finish running, before I attempted start. STARTED RIGHT UP and ran fine back to the hotel.
So ALL THAT CRAP above to ask a simple question. I think I was hopping on the bike and trying to start it before the fuel pump was done priming.
DOES THAT MAKE ANY SENSE at all. Never happened before, but I was thinking maybe because it was HOT TODAY (93 degrees) and not letting the fuel pump work...it might have cause a "vapor lock" of some sort.
Opinions...right now all is good...PEACE OF MIND is what I'm looking for.
Searcy, AR
Blytheville, AR (Hometown and the BEST BBQ Sandwiches in the world)
Arkansas Bikers Website
http://www.arkansasbiker.net
Garmin Zumo GPS Forums
http://www.zumoforums.com
arkiebiker is offline
post #2 of 31 (permalink) Old 03-21-2017, 07:25 PM
Bullypack3's Avatar
You really should always let the pump get up to pressure before you start the bike
2013 Vegas 8 Ball
ATS +4
Ness Intake
Miller Mufflers
pcV
Ness Fly Bars
And a nagging itch to add more
2016 CCT
Miller Mufflers
Lloydz ATS +4
Long Ride Shields Screen
Bullypack3 is offline
post #3 of 31 (permalink) Old 03-21-2017, 07:32 PM Thread Starter
arkiebiker's Avatar
I hope that's all it is ... and YES, I knew that...and YES, I was stupid as hell if that is indeed the issue (and even if it's not). Thanks.
Searcy, AR
post #4 of 31 (permalink) Old 03-21-2017, 07:33 PM
Good suggestion on the pressure. Perhaps the Intake Air Valve had to be reset? That's that clunky repetitive sound you hear a few seconds after you turn the key off...
post #5 of 31 (permalink) Old 03-21-2017, 08:12 PM
djh3's Avatar
If I'm not mistaken vapor lock went away with electric fuel pumps and fuel injection. It dont sit in a bowl to boil anymore. I would lean more towards the pump not up to pressure or a check valve or something wasnt "reset". Which is basically what I think the previous guys said.
2013 XCT added Jan 2015
djh3 is online now
post #6 of 31 (permalink) Old 03-21-2017, 09:46 PM
MaddogUSMC's Avatar
I always let my fuel pump prime and never had issues. The one time I didn't, I had similar symptoms as you do.
Sent from my SAMSUNG-SM-G870A using Tapatalk
arkiebiker and Michael T. like this.
2015 Victory Cross Country Tour 7/30/16 - 12/31/16
Lloydz ATS +4 and O2's disabled
Ultimate Seat and Driver Backrest
Alpine SPR-50 for front speakers and Polk Audio DB522 for the trunk speakers
Kuryakyn LED speaker grills
Michelin Commander II front and rear tires
Wolo Bad Boy air horn
Fusion LED kit for the whole bike
Tinted Klock Werks Flare (for winter riding due to fogging up)
Jax, FL
MaddogUSMC is offline
post #7 of 31 (permalink) Old 03-22-2017, 03:05 AM
A couple of things come to mind. Battery connections having a little build up causing enough resistance sometimes to act up. Easy to fix. Possible fuel pump issue. Maybe it's getting tired and not quite building enough pressure. One would think they either work or they don't but maybe not.
If you have time; it wouldn't hurt to remove and wire brush the battery terminals to eliminate that possible issue and it's a free thing to do. Just kind of a pain when on the road because of where it is and not having a lift to get at it easier.
BBob is online now
post #8 of 31 (permalink) Old 03-22-2017, 05:34 AM
TNXR's Avatar
I second what Bbob suggests. I always let my bike prime up before I start it but I had similar symptoms as you when my battery started going south. I would definitely check those connections and maybe a load test on the battery if you can swing by an auto parts store.
2011 Cross Roads Sunset Red
TNXR is offline
post #9 of 31 (permalink) Old 03-22-2017, 05:53 AM
BP6666VR's Avatar
Arkie, do you open the throttle just a little bit when starting the bike?
I don't but I read that helps some bikes start easier..
Andre
TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #10 of 31 (permalink) Old 03-22-2017, 07:30 AM
Had the same issues, let the pump cycle and then start. It was really hot and the bike was only cooling down for fuel and food stops. I now turn the key, flip the switch and wait. When the bike has been ridden like you had been I give it 10 seconds before I fire. I've also had to open the fuel cap and vent the tank but it was well over 100 and I had been in stop and go for over an hour. Pulled over to take a break and let the bike cool and it became angry.
I think you're fine and have a great trip.
2012 Victory Cross Country Tour, Sunset Red.
Parts added to make her louder, faster and more mine.
Stage 1 filter and pipes, Lloydz VFIII & ATW.
Clearwater Darla, LED GLO, emergency lights and siren.
Bushtec hitch and harness, Kompact Kamp trailer.
ChuglyXJ is offline
