Spark Plug Wire Boots - Victory Forums - Victory Motorcycle Forum
 10Likes
  • 5 Post By NOEMTZ
  • 2 Post By LILMAGS500
  • 1 Post By visionjohnny
  • 1 Post By Motorbikerx
post #1 of 9 (permalink) Old 03-22-2017, 10:30 AM Thread Starter
kezzy39's Avatar
Default Spark Plug Wire Boots
Is there a trick to taking off the plug wire boots from the spark plug? Mine seem like they are welded to the plug. I don't want to damage the wire boot.
2014 Cross Country. Stage 1 Exhaust Upgrade. LED Headlight. Keyless Ignition. Victory Chrome Bling.Winnipeg Manitoba Canada.
kezzy39 is offline
post #2 of 9 (permalink) Old 03-22-2017, 10:49 AM
NOEMTZ's Avatar
Long needle nose pliers, twist back and forth before pulling
www.noemtz.com
NOEMTZ is offline
post #3 of 9 (permalink) Old 03-22-2017, 11:02 AM
LILMAGS500's Avatar
I put a folded rag or towel in close to the plug and with a good sized screwdriver I put it tightly against the boot and pry them up . Only way to do it properly with out ruining the plug wire . If you attempt pulling up , you will leave the wire end attached to the plug 9 times out of 10 . Hope this helps .
Motorbikerx and kezzy39 like this.
LILMAGS500 is offline
post #4 of 9 (permalink) Old 03-22-2017, 11:06 AM
kezzy39 likes this.
post #5 of 9 (permalink) Old 03-22-2017, 11:07 AM
post #6 of 9 (permalink) Old 03-22-2017, 11:10 AM Thread Starter
kezzy39's Avatar
Excellent! Thanks. Ordered a pair of 45% long needle nose pliers.
kezzy39 is offline
post #7 of 9 (permalink) Old 03-22-2017, 11:10 AM
SpecialK likes this.
post #8 of 9 (permalink) Old 03-22-2017, 04:47 PM
philmonger's Avatar
Same problem when I changed my plugs at 30K. Wound up pulling the wire outta the boot on the back cylinder....Changed the plugs and stuffed the wire back in the boot and it ran OK. I then went to WD and ordered a set of Accel wires. They look much better than stock, although no difference in performance
2011 XR Midnight Cherry, Hard Bags, Vic htd grips & seat, Vic medium Windshield, unlocked speedo, Lloydz Air filter, VFC III, Lloydz ATS +4, Vance & Hines slip ons
1993 Vulcan 1500 (sold)
1981 Yamaha Seca 750 (ridden into oblivion)
1977 Honda 550 (sold)
philmonger is offline
post #9 of 9 (permalink) Old 03-22-2017, 07:13 PM
Motorbikerx's Avatar
Yeah that's how I do it too, except I've got an offcut of car heater hose I place under the screwdriver when levering upwards.
Not a drama.
visionjohnny likes this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
