OEM radio install issue --- rlaws797 ?? - Victory Forums - Victory Motorcycle Forum
post #1 of 1 (permalink) Old 03-27-2017, 09:16 PM Thread Starter
Default OEM radio install issue --- rlaws797 ??
After reading rlaws797 thread on successfully installing an OEM radio on a 8-Ball, I decided to do the same. I purchased a used radio and display from someone on here last year, and finally got around to installing it today......BUT ran into an issue. I removed the amp, replaced it with the radio module and hooked up the display to the connector labeled "DISPLAY". The display comes on and shows 'VICTORY", but nothing else. I tried disconnecting the battery (+) terminal, and then let it run for 10-15 min, but nothing. Any suggestions or did I miss something the 3 times I read rlaws797 thread ? The front and back of the fairing are still off....not sure if there is a safety switch tied into the turn signals. Someone PLEASE HELP !!!
Thanks everyone !!!
2014 Victory XC 8-Ball---Black Ice
4.5" Vance & Hines slip-ons
USA-Biker crash bars
Kuryakyn Sabertooth lights
Wolo Big Bad Boy Horn #619
Madstad brackets and 13" Med Gray OEM windshield
Big'un is offline
