Gear indicator - Victory Forums - Victory Motorcycle Forum
post #1 of 16 (permalink) Old 03-30-2017, 07:06 PM Thread Starter
catroadman's Avatar
Default Gear indicator
Just wrapped up an under drive pulley install along with a speed healer. Rode the than program the speed healer. The issue is the dash dose not show a gear change from 4 to 5 than when shifting into 6 dash only shows 5. On the dash it is as if the pattern goes 1,2,3,4,4,5... any thoughts? I did have a lot off the bike but other than cleaning the only major changes from last year was the pulley, new belt , speed healer, and grease fitting to the pivot for the shock
Sent from my C811 4G using Tapatalk
2011 X-country
catroadman is offline
post #2 of 16 (permalink) Old 03-30-2017, 07:17 PM
My speedo tuner does the same thing and KMC installed mine and couldn't quite figure out why but he didn't have alot of time to diagnose. Let me know if you find a solution I just never bothered trying to fix it.
2011 vegas 8ball PCV, swept pipes rpw modified baffles, llyodz vm1-dr cam, ats +4, 1/4 throttle, ud pulley and ness intake.
KMC tuned 114hp/125ft/lbs
shanko is offline
post #3 of 16 (permalink) Old 03-30-2017, 07:19 PM Thread Starter
catroadman's Avatar
Ok that makes me feel a little better
2011 X-country
post #4 of 16 (permalink) Old 03-30-2017, 07:38 PM
The gear indicator doesn't pick up what gear the bike is in from the transmission. Its actually being calculated by the ECU based on the speed of the bike and the rpm, obviously the calibration is based on the stock gearing.....Adding the under-drive pulley makes the rpm higher vs the speed of the bike, so it makes the gear indicator shows a lower gear.
post #5 of 16 (permalink) Old 03-30-2017, 07:39 PM
newj64's Avatar
Sorry I have no insight on your problem but I am interested in getting a speed healer. What speed healer did you have?
newj64 is offline
post #6 of 16 (permalink) Old 03-30-2017, 07:50 PM Thread Starter
catroadman's Avatar
@newj64 it is the heal tech speed o healer
2011 X-country
post #7 of 16 (permalink) Old 03-30-2017, 07:53 PM Thread Starter
catroadman's Avatar
Would that not make show it is in 6 when really in 5? And would the healer not correct this? The healer goes in the signal wire before it goes to the ECU. I wished I had noticed if it was doing this before I did the calibration. But I can always install the jumper and see what happens
2011 X-country
post #8 of 16 (permalink) Old 03-30-2017, 08:09 PM
Sorry mines a speedo DRD but same problem so must be something with the ecm as @PaiN said.
http://shop.12oclocklabs.com/index.p...&product_id=59
shanko is offline
post #9 of 16 (permalink) Old 03-30-2017, 08:15 PM
No...the bike is now running at a higher rpm for a given speed, so the indicator is showing a lower gear.
post #10 of 16 (permalink) Old 03-30-2017, 08:18 PM Thread Starter
catroadman's Avatar
For what the pulley does I can live with it. Going thru parking lots is much easier in first and bagging thru the gears goes pretty quick . Lol. Thanks for all the input guys. For what it is worth this has been the best site I have been part of
2011 X-country
