drive belt - Victory Forums - Victory Motorcycle Forum
 5Likes
post #1 of 12 (permalink) Old 04-04-2017, 08:09 AM Thread Starter
grampahawg's Avatar
Default drive belt
anyone found an after market supplier for drive belt on cross bikes??
2010 x-roads midnight cherry
cycleops black backrest rack
kuryakyn passenger floor boards
grampahawg is offline
post #2 of 12 (permalink) Old 04-04-2017, 08:19 AM
BP6666VR's Avatar
Question, steel frame and cross and visions have a different teeth counts?
I run a HD belt on my jackpot, but have the stock belt on my CCT
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 12 (permalink) Old 04-04-2017, 08:39 AM
vindex1963's Avatar
Got this from another site.
I believe I gained the following information:
1.There was one, and only one manufacturer of this particular belt.
2.It is used nowhere else; Victory specific (for aluminum frames).
3.The manufacturer is NOT allowed to make them unless they have a purchase order in hand from Victory; Victory owns the licensing rights to the manufacture of this particular design for the next 10 years.
4.Gates rubber co, at this time, has no purchase order from Victory.
5.As Victory has ceased production, there is no expectation of a purchase order from them.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #4 of 12 (permalink) Old 04-04-2017, 08:41 AM
BP6666VR's Avatar
Chain driven it will be then for my CCT
BP6666VR is offline
post #5 of 12 (permalink) Old 04-04-2017, 03:33 PM
@BP6666VR , for reference can you let me know specifically what HD belt you are using as well as what drive and rear wheel sprocket on your Jackpot. Or send a link to another thread you posted it in. I haven't been able to come up with it.
Thank you.
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #6 of 12 (permalink) Old 04-04-2017, 03:48 PM
merksys's Avatar
As vindex1963 said, there is no substitute for a stock-pullied aluminum frame (Vision, cross bikes). It's 28mm wide by 154T. If you have an underdrive pulley, there are a couple of options: Polaris #3211168, which is an Indian belt, and Harley #40145-07, which is the belt for the international spec V-Rod. Both are 152T. The Indian belt is 24mm and the V-Rod belt is 1".
I haven't actually mounted one of these up, but I did the math and it should put the axle 3/8" - 1/2" forward from the stock location.
Chattanooga Mark and broggyr like this.
merksys is offline
post #7 of 12 (permalink) Old 04-04-2017, 03:57 PM
Are the tooth sizes the same?
post #8 of 12 (permalink) Old 04-04-2017, 03:59 PM
merksys's Avatar
Yes, 18mm pitch.
merksys is offline
post #9 of 12 (permalink) Old 04-04-2017, 04:04 PM
merksys's Avatar
Originally Posted by merksys View Post
Yes, 18mm pitch.
Sorry, brain fart. Make that 14mm.
merksys is offline
post #10 of 12 (permalink) Old 04-04-2017, 07:01 PM
BP6666VR's Avatar
Thank you.
I am using the belt that Half Crazy found a few years ago, ok I will look up the thread
EDIT:
https://www.victoryforums.com/showthread.php?t=10015
BP6666VR is offline
