Changing fuel filter - Victory Forums - Victory Motorcycle Forum
 28Likes
post #1 of 33 (permalink) Old 04-07-2017, 10:18 PM Thread Starter
rainman123's Avatar
Default Changing fuel filter
I'm planning on changing my filter soon and have just the filter and was wondering if the old one just comes off the hose so u can put the new one on
2012 crossroad
08 r3t traded for xr
06 rocket classic totaled
98 t-bird traded for rocket
73 sportster sold
72 honda 350 long gone
06 rocket3 classic
rainman123 is offline
post #2 of 33 (permalink) Old 04-07-2017, 10:24 PM
No sir, the old fuel filter assembly comes off the fuel pump assembly. The Vic SHop has a great video for you here:
Bobbyd85 and SkInM4N like this.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #3 of 33 (permalink) Old 04-07-2017, 10:42 PM Thread Starter
rainman123's Avatar
So what u r saying is that u cannot change just the filter but have to change the whole unit
2012 crossroad
73 sportster sold
06 rocket3 classic
post #4 of 33 (permalink) Old 04-07-2017, 11:21 PM
vindex1963's Avatar
So it would seem.
I'll direct you to a thread already going on fuel filters. Click.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #5 of 33 (permalink) Old 04-08-2017, 03:07 AM
Originally Posted by vindex1963 View Post
So it would seem.
I bet it's just a matter of removing the one-time crimped clamp and replacing it with a worm gear clamp right at the filter or another one-time clamp.
In looking at the video it looks like the white plastic piece and clip that holds it on is reused when using the Quantum filter. At the low price of $15 or so bucks for the Quantum filter and the lack of availability of the stock Vic filters; I think it would be worth it to just give it a go. The very worst that might happen is a piece of gas coupler hose would be needed between the filter and existing hose to the pump to make it work but I'd bet that wouldn't even be needed.
One should be mindful of what kind of clamp or hose is used since this is submerged in gas. It needs to be something that will handle it without dissolving.
An interesting note is I replaced the filter in my 04 Kingpin last year when I painted it and it has dual filters while the X bike has just one. I guess the KP setup was an overkill.
Here is the one and only picture I took of that project. I wish I had taken more. Notice the one-time use clamps.
BP6666VR and SkInM4N like this.
post #6 of 33 (permalink) Old 04-08-2017, 03:59 AM
I just purchased two new fuel filters and they came with spike fits for the end and hose-clamps not the whole assembly.
Here's a pic.
Chattanooga Mark and BP6666VR like this.
post #7 of 33 (permalink) Old 04-08-2017, 04:09 AM
BP6666VR's Avatar
Here's a pic.
This should do fine mate, the original is a crimpfit, so after cut the original filter off, then use a short hose that fits over the filter nipple and the stock fuel hose at the pump.... Then hoseclamp them and be done with it....
Andre using TaPaTaLk
Chattanooga Mark likes this.
Cross Country Tour 2014 [B]
BP6666VR is offline
post #8 of 33 (permalink) Old 04-08-2017, 04:25 AM
Thanks, after watching the few vids that are out there on changing the Cross bike fuel filters I figured that's how it would go together. One of the filters is for me the other is for @broggyr we're planning a "maintenance day" where we change the fuel filters and brake fluids in our bikes. This way we can share the suffering ...lol
post #9 of 33 (permalink) Old 04-08-2017, 04:52 AM
BP6666VR's Avatar
I posted the following on the "Tinker Time"
removed the dented tank and installed the new tank, and new fuel rail hose....
Note that the fuel filter looked "ok" to me, and it looks to me if victory decides to stop supporting the new filters it shouldn't be long before a company makes a plug and play hose and filter, it is just crimped on the pump & filter nipple, so a hose clamp could be used for that... No biggie for the future...
I used a knife bent like the picture, super easy to get that fuel pump hose out of the hole, also note I reused the rubber gasket, perfect condition, no leaks, etc etc....
If you look at the video on YouTube from the vicshop then you can see the pump and filter fit trough the hole, but there is a hard rubber hose with of course a mash protect hose that is hanging up under the edge....
anyway this easy tool make sliding that @$'/*! Hose right passed that ridge...
You make the tool, from a old blund knife and stare at the tank with the stuck pump for 5 minutes, then you can feel that hose is on a 45 angle so the bent knife must align with that hose and removing the pump is a 10 second job, putting that hard fuel hose back in the hole is a 20 second job
SkInM4N likes this.
BP6666VR is offline
post #10 of 33 (permalink) Old 04-08-2017, 05:08 AM
Thanks again Andre' ...but I'm just going to use this tool
