Stage 1 Muffler Rattle Noise - Victory Forums - Victory Motorcycle Forum
 9Likes
post #1 of 11 (permalink) Old 04-22-2017, 08:29 AM Thread Starter
kezzy39's Avatar
Default Stage 1 Muffler Rattle Noise
Purchased the stage 1 tri oval exhaust a year and a half ago. Only 8k miles on them. The right exhaust now makes a loose rattling sound when I Rev the engine in neutral. Anyone experienced this on the Vic stage 1's ? Is there a baffle or tube coming loose inside? Can I loosen the 2 bolts on the chrome tip on the lower side to gain access for a fix?
2014 Cross Country. Stage 1 Exhaust Upgrade. LED Headlight. Keyless Ignition. Victory Chrome Bling.Winnipeg Manitoba Canada.
kezzy39 is offline
post #2 of 11 (permalink) Old 04-22-2017, 08:58 AM
This noise you hear likely isn't from the muffler, I'd lay bets it is the directional exhaust valve at the right for the cross over that's rattling.
kezzy39 likes this.
post #3 of 11 (permalink) Old 04-22-2017, 09:02 AM Thread Starter
kezzy39's Avatar
So is this directional valve coming loose? I purchased 5 year extended warranty on my Vic. Wonder if that is a warrantable issue.
kezzy39 is offline
post #4 of 11 (permalink) Old 04-22-2017, 11:31 AM
If you have a warranty and a new noise, take it to the dealer.
broggyr and kezzy39 like this.
post #5 of 11 (permalink) Old 04-22-2017, 01:00 PM
Foto Joe's Avatar
Check the hose clamps holding the heat shields on they're the easiest fix and you'll save yourself the time of taking it to the dealer for a fix you can do with a nut driver.
broggyr, kezzy39 and FoFo like this.
@"[email protected]_ _ _
Ambition is a poor excuse for not having enough sense to be lazy.
2017 Cross Country
Stage 1 & Tri-Ovals
Foto Joe is offline
post #6 of 11 (permalink) Old 04-22-2017, 01:18 PM
You're 100% right, I just assume when someone asks for help they've already checked the simple, basic stuff.
kezzy39 likes this.
post #7 of 11 (permalink) Old 04-22-2017, 02:06 PM
when pipes are cold pull your saddle bag. Then start hitting the muffler and pipe with you hand and see if you hear a sound.
I believe there is a allen button head bolt on the back side of the muffler
kezzy39 likes this.
post #8 of 11 (permalink) Old 04-22-2017, 02:30 PM Thread Starter
kezzy39's Avatar
Never thought of that. I will.
FoFo likes this.
kezzy39 is offline
post #9 of 11 (permalink) Old 04-22-2017, 02:31 PM Thread Starter
kezzy39's Avatar
Very valid point.
kezzy39 is offline
post #10 of 11 (permalink) Old 04-22-2017, 02:33 PM Thread Starter
kezzy39's Avatar
I'll use a rubber mallet. Another good idea. Thx
kezzy39 is offline
