Rear wheel wobble - Victory Forums - Victory Motorcycle Forum
 16Likes
post #1 of 17 (permalink) Old 04-27-2017, 03:44 PM Thread Starter
snojunkie's Avatar
Default Rear wheel wobble
Hello everyone, a few weeks ago I took my 2014 CCT out or storage. I went through all the systems to make sure everything was up to par. ( Battery charged, tire pressures, shock pressure, brakes, etc...) Upon everything checking out I proceeded to go for a ride. As I took off, everytime that I would get in or out of the throttle upon acceleration or deceleration the rear end would whip a bit to the left as I accelerated and back to the right as I decelerated. I took it to my dealer where the mechanic rode it and said as I did that he had never felt anything like that. I rode it about 100 miles that day, and the more I rode it seemed to quit doing it. The next day the wife and I rode about 300 miles and it happened once right of way but no more after that. I rode about 600 miles with no issues thinking it had worked itself out. Fast forward, I was not able to ride for 11 days and took it out 2 days ago and it was doing it again. After about 15/30 miles if seemed to go away again. It is not a sustained feeling, only right when you roll on the gas , or out of the gas it whips a bit left and back to the right. Nothing was done to the bike for 5 months it just SAT in a building collecting dust. Has ANYONE ELSE experienced, or heard of something like this?
snojunkie is offline
post #2 of 17 (permalink) Old 04-27-2017, 03:51 PM
Do you have any type of tire sealant/balancer in the rear tire? Does the bike tires sit on concrete or some other type of hard flooring when stored?
snojunkie likes this.
post #3 of 17 (permalink) Old 04-27-2017, 04:23 PM
If one direction change occurs when you accelerate and it changes again as you decel, sounds like the axle might have some play in it. Are the adjusters snugged up properly? Swing arm bearing play?
Put the bike on a lift - can you move the rear wheel side to side or front to back? How about the swing arm?
Worn wheel bearings?
RICZ and snojunkie like this.
post #4 of 17 (permalink) Old 04-27-2017, 04:28 PM Thread Starter
snojunkie's Avatar
There is no sealer or balance added, and it has always sat on concrete. I have Dunlop E3 tires with about 8,000 miles on them. I always watch my tire pressure so there's plenty of tire tread left. Belt tension is good and everything is tight. If it was a worn axle or wheel bearing why does it go away after riding it for awhile ? I will put it on my lift again and check everything out one more time. I for the life of me can't figure out how you can park a bike running perfectly in December, and 5 months later start that same bike and have an issue like this. PLEASE continue to throw ideas at me, I will check everything to get PEACE OF MIND. Thanks, Snojunkie
post #5 of 17 (permalink) Old 04-27-2017, 04:34 PM
I'd get the bike up on a lift and check the rear end/swingarm as @broggyr suggested. I'm very suspicious of the rear tire being damaged or faulted internally. Whatever you do, you should probably refrain from riding too many miles, especially with a passenger until this gets resolved.
post #6 of 17 (permalink) Old 04-27-2017, 04:37 PM
My brother-in-law had a very weird "ka-CHUNK-a-CHUNK" sound on his 2012 Fat Bob in his rear wheel that wasn't regular at all. Only happened during acceleration, and seemed intermittent. Turned out the bike ate the rear wheel bearing...
"ka-CHUNK-a-CHUNK"
and no, that's not his motor.
post #7 of 17 (permalink) Old 04-27-2017, 06:01 PM
Kurbs's Avatar
If it was a ka chunk ka chunk...thats just a normal Vic transmission. Ignore it.
2012 Pin
Torque Tubes, VM-1 cams, PCV, Throttle ring, ATS
Kurbs is offline
post #8 of 17 (permalink) Old 04-27-2017, 06:04 PM
Am guessing the cords on the inside of the tire are bad. The more you ride the hotter the tire gets so the cords on the inside tighten up.
You might be able to find out easier then pulling wheel by putting in more air say make it 50 pound and see what you feel.
Next winter put tires on some wood like plywood. Cement does harm tires
PaiN and snojunkie like this.
post #9 of 17 (permalink) Old 04-27-2017, 08:28 PM
depot picker's Avatar
I'm guessing one of the fork tubes leaked enough to be a factor, but then I don't know shit and I have been a drinkin.
catroadman and Motorbikerx like this.
depot picker is offline
post #10 of 17 (permalink) Old 04-28-2017, 04:19 AM
SuperDog's Avatar
I concur with this.
This, not so much
Please do expand on this, as I have never ever heard such a thing, nor have I ever had any issues with parking anything on concrete for extended periods (years)
Out in the yard on dirt or gravel, now thats another story and has nothing to do with harm to the tires (That is the least of your worries ).
"Be Water, My Friend" Bruce Lee 1971
2013 CCT Grasshopper Drivers Backrest, PVC Self Made 1/4 turn Throttle Ring, Thrush Self Modded Mufflers, Kuryakyn 4526 Tour-Tech Adjustable Cruise Mount/Tour-Tech Pegs
SuperDog is offline
