Shock air setting after drop kit - Victory Forums - Victory Motorcycle Forum
 2Likes
post #1 of 14 (permalink) Old 05-31-2017, 11:27 PM Thread Starter
Default Shock air setting after drop kit
How much extra air pressure are you adding to the suggested pressure after you install the 1.5" drop, 10%? 20%?
thanks all
Renoooorider
Hammy
2016 Victory Cross Country
Reno Nevada
Renorider is offline
post #2 of 14 (permalink) Old 06-01-2017, 01:02 AM
I haven't lowered my XR, but I'll take a flyer and suggest 25 psi for a start. If the rear feels too harsh, loose some air. If to soft, add some air. Its really quite subjective and personal.
post #3 of 14 (permalink) Old 06-01-2017, 06:44 AM
roboots21's Avatar
Personally, I didn't change the setting in the rear shock after my drop kit. I went with a 1" drop kit and I stayed at my setting from there. I run 31 psi in mine and I kept the setting the same.
**2012 Victory Cross Roads** Black Betty - 118 HP/122 TQ - Tuned by Lloydz
-- Lloydz Performance/PCV/Atom Bombs/UDP/Victory Stuff/1" Drop/Corbin/Accel/Mastiff Stick/Kuyrakyn/Stebel/HMD/Barnett/Ness/21" 'Gunner'/Avons --
**2008 Victory Vegas Jackpot** Black Beast
-- Lloydz Performance/Vic Swepts/RPW/KMPS/Ness/Avons/MBW/Kuryakyn/Custom Machined Bits --
2006 Victory Vegas - Spongebob (TRADED)
1982 Honda Magna V45 (SOLD)
roboots21 is offline
post #4 of 14 (permalink) Old 06-01-2017, 08:33 AM
I dropped mine 1" and found 50 psi to be about right but it really depends on your weight and if you're gonna have a passenger.
The thing you don't want is for your shock to bottom out. It will lose its ability to hold air if it happens enough times.
BBob is online now
post #5 of 14 (permalink) Old 06-01-2017, 01:24 PM
Keep in mind you can't add air in the middle of the ride. Start out with maybe 50 and go from there. It depends on how big you are
post #6 of 14 (permalink) Old 06-01-2017, 01:28 PM
Say add a air line to your existing line and get it out from under the side cover. Make it easy to add air
https://www.amazon.com/dp/B00DHUK1D6...SIN=B00DHUK1D6
post #7 of 14 (permalink) Old 06-04-2017, 03:27 PM
DwayneS's Avatar
thanks all
Renoooorider
The decal on the underside of the right bag has air pressures for "LOW". Mine says 42 pounds for a 200 pound rider.
2016 CCT/2019 Roadsmith Trike conversion
2016 Cross Country Tour
2012 Cross Country - Gone but not forgotten
2008 Yamaha V Star 1100 - Nice but not very comfortable for long rides
2004 Yamaha V Star 650 - Not a road bike but short rides only
OLD Honda 750 - Started me on my road to sin AGAIN but then it was free
DwayneS is offline
post #8 of 14 (permalink) Old 06-05-2017, 08:16 AM
id-man's Avatar
Huh, why not? I like to keep my ride as cushy as possible but if I find myself on a stretch of particularly dippy road that has me bouncing up and down it's very easy to pull over and add some air to stiffen up the ride, let it back out when back on smoother surface.
Cape Cod, MA
2010 Cross Country "Scrolly"
www.VicWrapz.com
id-man is offline
post #9 of 14 (permalink) Old 06-05-2017, 08:21 AM
I think he meant as you ride down the road but if someone has a compressor set up it could be as simple as pushing a button. I've often thought any premium touring bike with air shocks should have them stock or at least have it as a reasonably priced option; like under $500.
BBob is online now
post #10 of 14 (permalink) Old 06-05-2017, 08:47 AM
thefreudy's Avatar
Keep in mind that you have to use a low pressure air pump for the air shock or you will rupture the air bladder inside the shock. Never hook a compressor driven source up that air shock unless you can limit the pressure to extremely low pressures. Ask me how i know this............
Matt - Nashville, TN
2012 XCT - Solid Black
Klock Werks 8" Flare
Big Gonzos Exhaust
Lloydz 1/4 Turn Throttle Ring
ProAuto LED Headlight
thefreudy is offline
