Slow Oil Leak on 2015 Cross Country - Victory Forums - Victory Motorcycle Forum
 16Likes
post #1 of 20 (permalink) Old 07-03-2017, 03:12 PM Thread Starter
Default Slow Oil Leak on 2015 Cross Country
I've had my 2015 Cross Country, 6,000 miles, less-than 2 months and I noticed a slow oil leak last week. I wiped everything down to 1) ensure I was looking at an active leak, and 2) determine where it's leaking from. I did a 300 mile trip two days ago and it is most definitely an active leak. It's not leaking fast enough to prevent any riding, but it's certainly a concern. I just can't determine where it's leaking from - I'm hoping your collective experience can help out before I resort to taking it to a (former) dealership.
It's leaking from the front underside of the engine, on the right-hand side. Behind the oil cooler radiator, below the heads, to the front of the transmission case cover (my terminology may be incorrect: small cover on the right-hand side that has "Overdrive 6" printed on it). Photos attached.
Based on reading through other forum posts (both here and other sites), it sounds like sloppy oil changes and bad filters/seals have caused this for others. On my bike, there is zero oil residue around the filter or the drain plug, which rules out the easiest resolution :\ . All the residue that I'm seeing is up at the front of the engine instead of at the rear. I also checked the air filter and commonly leaky tubes, but all surfaces on the rear, side and top of the engine are oil-free.
It almost looks like it's coming from the seam between the starter and the block/case. However, I can't tell for sure since the wind just spreads the oil as soon as it leaks out of wherever it comes from. Just below the starter appears to be a regulator/rectifier which I have not yet removed to get a better visual - it could be originating there as well.
TLDR; slow oil leak near the starter on the front of the engine. Has anyone else encountered this before?
Tetto is offline
post #2 of 20 (permalink) Old 07-03-2017, 07:33 PM
Have you checked the oil cooler connections? The oil level? You do know to check the oil level, you come back from a ride over a half hour, let the bike set on the side stand for a spell and then slowly raise it to vertical and slowly lower it back onto the stand. Then you can check it. It might have been over filled.
Tetto likes this.
post #3 of 20 (permalink) Old 07-03-2017, 09:03 PM Thread Starter
Well... this is embarrassing. I pulled about 1/2 quart out with a vacuum pump and the dipstick is barely below the full line now.
The dealer reported an oil change when they got it in and I haven't put enough miles on it for the next oil change yet. The color of the oil is about what I expect to come out of my diesel too. I assumed the dealer did what they said, and did it properly. Bad on me for not checking it.
Now that I've put ~2,500 miles on an overfilled engine, we'll see what damage has been done. I've read mixed reports on what may or may not be damaged, namely various seals. I'll be changing the oil when my kit arrives in the next 2 days, then see if the leak continues.
Happy 4th of July!
Tetto is offline
post #4 of 20 (permalink) Old 07-03-2017, 09:55 PM
??????????Shouldn't bike be vertical to check the oil??????????
TIMONBIKRIDER is offline
post #5 of 20 (permalink) Old 07-03-2017, 10:12 PM Thread Starter
Yes, but I think there is misunderstanding: he's explaining how to check it with one person. By slowly tilting the bike to vertical then setting it back on the kickstand, this will let the oil 'mark' the dipstick and allow the oil to be checked with only one person (instead of a second person holding the bike vertical while another person checks the dipstick).
Tetto is offline
post #6 of 20 (permalink) Old 07-03-2017, 10:26 PM
vindex1963's Avatar
You didn't hurt anything and I bet you have a lot of blow by in the air filter area so don't be surprised to get some drips on the back cylinder.
RICZ and Tetto like this.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #7 of 20 (permalink) Old 07-03-2017, 11:07 PM
Here's another trick to make checking the oil level easy peasy. When you know you have the correct level, park the bike on the side stand and the next day - when the engine is cold - remove the dipstick, wipe it off and replace it. Note: readings are taken with the dipstick screwed in. Remove the dipstick again and with a triangular file, or similar tool, carve a line at that oil mark on both sides of the dipstick. Now you can take level readings with a cold engine and the bike on the side stand.
post #8 of 20 (permalink) Old 07-04-2017, 05:36 AM
TNXR's Avatar
My selling dealer did my 500 mile service as part of the deal on the bike. He really didn't do crap but he did overfill my oil by 1.5 quarts. I didn't know this till half way doing 75 down the interstate I felt something warm on my left leg. Oil was coming out of the top of the primary! I got it home, let it cool down and used a turkey baster to remove oil till it got to the correct level. I never went back to that dealer and now since the closing of Victory he is the only dealer left who will do warranty work and sell parts in my area.
2011 Cross Roads Sunset Red
TNXR is offline
post #9 of 20 (permalink) Old 07-04-2017, 12:52 PM
You could put a 2X4 under kickstand and take your reading.
Here is a tip for you. With bike vertical just stick oil dipstick in hole. Now pull it out and read it. Oil should be on the add mark.
That is the same distance as if you screwed it in and then out. If on add mark it is full.
If my grammer is not correct. Mr Perfect VCC14 will correct it for me
post #10 of 20 (permalink) Old 07-04-2017, 03:38 PM
Default oh that smell! Tip
Another tip for those with a nose for oil. First part of July was coming back home from southern Arizona. Along I-10 freeway I thought I smelled oil. Figured it was a car in front of me or to the side. Got home checked the oil. It was low. Got to checking. Found the PCV or crankcase vent tube had split. The one that comes off the top of your crankcase behind the rear cylinder. You follow that tube up and on the X bikes it goes into the top of the main frame were it is sucked into the engine. The tube hooks to a 90-degree rubber elbow at the top. The rubber elbow is very thin/very cheap, less than a 1/16" thick the way I remember. I went down to O-Reillys or AutoZone. I bought a PCV hose for a Chrysler product, it was about a foot long with a 90-degree elbow on one end. Cut off the elbow end and stuck it on the bike. The one for a car is much thicker, maybe 1/4". Keep this in mind on a trip if you smell oil, my bike was over a quart low when I got home.
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
