Shift shaft slop warning. - Victory Forums - Victory Motorcycle Forum
 27Likes
post #1 of 31 (permalink) Old 07-12-2017, 11:01 AM Thread Starter
Richie271's Avatar
Default Shift shaft slop warning.
I just installed a copper oil drain plug washer on the shift shaft of my bike, to eliminate the shaft slop, (missing down shifts.) After reinstalling the primary case cover and buttoning every thing up, some how wound up with only gears 1 and 2, and neutral. In 2nd, the shift lever stays up. Moving it down manually, does not enable a shift into third.
This morning, I discovered on that other site, that there are two different thickness of drain plug washers on the market. If you are unfortunate enough to use the thicker washer, (witch I did), the shift shaft will bind and not work properly. Others have had this problem too. SO BE WARNED!
This quote from the other site.
Just did this yesterday. Very easy job with you guys' help. I did notice that the washer I got was twice as thick as normal. I think Vic is starting to use a thicker washer. This thicker washer, when installed, will only allow 1st and 2nd gear to engage. Don't ask how I know that. Wish I would have measured the thinner one so I could post the differences. One looks like a nickel and the other looks like a dime is the best I can explain it as far as thickness goes. Just thought I'd share to point out the different thickness washers being put out there.
broggyr, LILMAGS500, Joe_ and 1 others like this.
Richie271
Long Island, NY
2010 Cross Roads. Midnight Cherry.
Richie271 is offline
post #2 of 31 (permalink) Old 07-12-2017, 11:18 AM
Thanks,
This is one of the things on my to do list.
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #3 of 31 (permalink) Old 07-12-2017, 05:22 PM
Motorbikerx's Avatar
Thanks!
Upgraded mine 6 months ago and a big difference in shift quality.
Should've been done at the factory I reckon.
BEWARE thick oil drain washer. Anyone that ain't done it yet.
More on my latest shifting problem elsewhere.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 31 (permalink) Old 07-20-2017, 05:43 AM
SkInM4N's Avatar
For us Noobs, can someone explain this mod to me? Not what it does but more how to perform it.
Thanks,
Skin
"Trail is life..."
#rideyoureffingbike
2016 Victory CCT "Miss Pearl"
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
- Taylor Thundervolt wires
- Victory Tri-Ovals (no baffles)
SkInM4N is offline
post #5 of 31 (permalink) Old 07-20-2017, 06:51 AM
ForestGiant's Avatar
I have the bushing kit from Witchdoctors. Past Sunday I tried to do the brake side first. I could not watch the witchdoctors video as my computer is dying of old age ( 2008 Vista ). I have a new computer ready to pick up a best buy, Saturday I guess. The job looked straight forward except I could not get that pivot bolt out and could not figure what is holding it in. Should anyone know I am all eyes. Chuck
ForestGiant is offline
post #6 of 31 (permalink) Old 07-20-2017, 07:46 AM
What is being referred to in this post is not the shift lever slop (which WD bushings fix), but the shifter shaft where it protrudes from the primary case. There is a bit of slop in there and the thinner crush washer is being used to fix that. You have to remove the primary cover and fit the crush washer on the shift shaft, then put the primary cover back on. There is a thread here, somewhere, on how to do this.
SkInM4N likes this.
post #7 of 31 (permalink) Old 07-20-2017, 07:55 AM
SkInM4N's Avatar
That's the answer I was looking for. I'm not going to pull my primary cover for this alone, but I will put it on the to-do list whenever I go in there. Thanks for the info, B
Skin
PS- I know you ride a lot but Rever says otherwise
"Trail is life..."
#rideyoureffingbike
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
SkInM4N is offline
post #8 of 31 (permalink) Old 07-20-2017, 08:04 AM
Skin
Well I can guarantee that it's well worth pulling the primary to do this mod,
wishes now that I'd done mine as soon as I found out about it, as it very well could have saved some shift ratchet wear that resulted in that having to be changed too.
The shift ratchet don't need much wear to malfunction.
HowardGNelson and SkInM4N like this.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #9 of 31 (permalink) Old 07-20-2017, 08:11 AM
SkInM4N's Avatar
You make a valid point...perhaps I shall rethink this
Skin
"Trail is life..."
#rideyoureffingbike
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
SkInM4N is offline
post #10 of 31 (permalink) Old 07-20-2017, 08:12 AM
Sorry I don't track my daily commutes. I'll try to be better.
SkInM4N likes this.
