Video - Belt Tension - Victory Forums - Victory Motorcycle Forum
 18Likes
  • 11 Post By Pauljp
  • 1 Post By RICZ
  • 1 Post By Victor57
  • 2 Post By Pauljp
  • 2 Post By Vinish
  • 1 Post By TNXR
post #1 of 10 (permalink) Old 07-17-2017, 02:45 PM Thread Starter
Pauljp's Avatar
Default Video - Belt Tension
I made a quick video on how I measure the tension on the drive belt of my 2014 Cross Country Tour.
I may do it differently than others, but as I say in my video, "...as long as you get the numbers, there is no wrong way."
Click here to watch the video.
Let me know what you think.
Thanks
Paul
Paul
Gatineau Quebec, Canada
Pauljp is offline
post #2 of 10 (permalink) Old 07-17-2017, 03:51 PM
Watched it, liked it....thanks again for an excellent production Paul.
post #3 of 10 (permalink) Old 07-17-2017, 05:37 PM
TNXR's Avatar
Another great video and very well made, good job Paul! I have fixed the tension and aligned my belt a few times now and have gotten pretty efficient at it but come across a new one last week. Decided to check my belt because I thought I heard it chirping and it was at 1.5" deflection. Loosened axle bolt, tightened adjusters, got belt at 1.25 inches, aligned belt and checked tension again, torqued axle nut, checked deflection one more time then buttoned everything up. Checked my belt again just for the hell of it last week and it was back to 1.5" deflection at the tightest spot. Kinda lost on this one.
2011 Cross Roads Sunset Red
TNXR is offline
post #4 of 10 (permalink) Old 07-17-2017, 06:43 PM
Another good video, and just in time. I have the belt chirp when my bike is cold so I need to check my belt. Thank You for these video's.
Pauljp likes this.
2013 CCT Boardwalk Blue
Trapped in the Republik of Illinois
"When you are dead, you don't know that you are dead. It is difficult only for the others.....It is the same when you are Stupid"
Victor57 is offline
post #5 of 10 (permalink) Old 07-17-2017, 07:27 PM Thread Starter
Pauljp's Avatar
After you tightened the axle nut did you re-torque the adjuster nuts?
The only way the belt can loosen is if the axle moves forward. And I know even with a properly torqued axle nut, if you hit the throttle hard enough it will move the axle.
The adjuster nuts shouldn't move much, but it will ensure the axle can't move forward.
Just a thought.
RICZ and SkInM4N like this.
Paul
Pauljp is offline
post #6 of 10 (permalink) Old 07-18-2017, 04:04 AM
SkInM4N's Avatar
Watched, liked, commented. Well done again, Sir.
Skin
"Trail is life..."
#rideyoureffingbike
2016 Victory CCT "Miss Pearl"
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
- Taylor Thundervolt wires
- Victory Tri-Ovals (no baffles)
SkInM4N is offline
post #7 of 10 (permalink) Old 07-18-2017, 05:15 AM
TNXR's Avatar
Just a thought.
I think you may be right. I only torqued the a adjuster nuts the first time I checked my belt (5 years ago) and didn't like how it messed my alignment up. I think the manual calls for torquing the adjustment bolts first then the axle nut. Would it be OK to torque down the axle nut first, put the bike on the ground and then do a final tightening of the adjusters?
TNXR is offline
post #8 of 10 (permalink) Old 07-18-2017, 07:05 AM
I suspect you have this backwards. It would make no sense to torque the adjustment nuts first as doing so would change the belt tension dramatically as they would have no force other than the belt tension to resist the torquing. The steps are: adjust tension, adjust alignment, recheck tension, tighten axle nut, recheck tension and alignment, torque adjustment nuts, recheck tension and alignment. Okay, I'm a bit fixated on the tension and alignment
G'day,
Vinish
SkInM4N and Spacecoast like this.
G'day,
Vinish
Our patriotic stable:
Red 2012 XCT (my bike for NC)
Vinish is online now
post #9 of 10 (permalink) Old 07-18-2017, 08:21 AM
G'day,
Vinish
This is the process I follow, generally. But i i tighten the axel nut snug at first. check tension and alignment, then tighten a little tighter, recheck... the torque to 65 ft lbs, then torque the adjuster nuts.
Roanoke, Virginia (originally from Ithaca, NY)
USMC - Vietnam
2013 Victory Cross Country Tour
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
Dynoed By Nick at 804 MotorSports
1" tank risers
O2 unplugged
1/4 turn ring
JPokerwinski is offline
post #10 of 10 (permalink) Old 07-18-2017, 02:16 PM
TNXR's Avatar
You guys are right, looked over my notes from when I did my 500 mile adjustment. I guess it has been so long since I last messed with the belt I got things backwards. Looks like I'll be messing with the belt again this evening. Gotta get things right before I head out for my little 2 day BRP ride! Just looked at the weather forecast for Friday and Saturday, gonna be HOT!
SkInM4N likes this.
TNXR is offline
