Kickstand pad barrel nut help - Victory Forums - Victory Motorcycle Forum
 3Likes
post #1 of 14 (permalink) Old 07-20-2017, 05:01 PM Thread Starter
TNXR's Avatar
Default Kickstand pad barrel nut help
I ordered a replacement OEM kickstand pad for my XR and the place I bought it from showed barrel nuts as for replacing the rivets. I got it in the mail yesterday and just the pad, no barrel nuts. The company said Polaris had just recently quit including the barrel nuts and apologized and offered me a full refund or 20% refund if I wanted to source my own barrel nuts out. Can anybody tell me what size and length barrel nuts to get?
**I finally got the search function to show me what I needed but any other input would be welcome**
https://www.victoryforums.com/34-vict...placement.html
2011 Cross Roads Sunset Red
TNXR is offline
post #2 of 14 (permalink) Old 07-20-2017, 06:10 PM
sheets's Avatar
I think a 6mm bolt will do it. I made my own out of piece of truck bed liner. Recessed the hole so the head of the bolt is recessed from the surface in contact with the ground. Put the nuts on top so they are easy to get to when time to replace. Used a dremel tool to remove the rivets.
Chattanooga Mark and RICZ like this.
2014 XCT - blue/silver - 11" Madstad windscreen - hyd clutch - Black LED headlight -
Vic backrest - Vic short antenna - Clearwater fender-mount LED driving lights -
Vic Tri-Oval mufflers - Lloydz air filter - PC/V - Dyno tuned @ RPM, Yuba City, CA. -
sheets is offline
post #3 of 14 (permalink) Old 07-20-2017, 06:43 PM
ACE hardware will have them but they might not be metric
post #4 of 14 (permalink) Old 07-21-2017, 06:38 PM Thread Starter
TNXR's Avatar
It doesn't matter if it is metric or SAE, as long as they fit.
TNXR is offline
post #5 of 14 (permalink) Old 07-21-2017, 09:10 PM
Forget the barrel nut thing. Use finishing (acorn) nuts and screws as Sheets did above.
post #6 of 14 (permalink) Old 07-22-2017, 12:16 PM
sheets's Avatar
The material is a byproduct of recycling - ground-up rubber from old tires. Is about 3/4" thick. Comes in a mat form to fit various size pickup truck beds. My old truck died and went away . . . I kept the bed liner to be used another day. The OEM pad lasted one year. Had I known about the "puck" shown in the other thread I probably would have procured one of those. I don't do Facebook (or Paypal) - is why I hadn't been aware of the Vic puck product.
sheets is offline
post #7 of 14 (permalink) Old 08-25-2017, 10:11 PM
I need to replace my pad and noticed when the kickstand is down you can push it down about an inch toward the ground. It's like there is slack where it pivots. Is this normal?
2011 Cory Ness XC
psimpson is offline
post #8 of 14 (permalink) Old 08-25-2017, 10:23 PM
OzVegas's Avatar
Most likely worn the pivot bolt and at worse the sidestand hole, DIY fix weld hole and redrill and new bolt or OEM
Nothing like the freedom of a bike , except the OCD of always buying new stuff for said bike!
2014 Vegas 8Ball
Ness fly bars
Ness grips and pegs
opened stage1 straight pipes
120 -21 front tyre
6in rearward front guard reset
Bandit solo seat
custom open drive cover
wedge delete
key relocate
Led multifunction flashers
Led headlight
Progressive rear shock
Graphite metallic highlights
etcetc
OzVegas is offline
post #9 of 14 (permalink) Old 08-26-2017, 07:53 AM
depot picker's Avatar
This is by design. It allows the sidestand to flip up if you forget and leave it down. I have used it 3 times that I'm aware of.
depot picker is offline
post #10 of 14 (permalink) Old 08-26-2017, 02:22 PM
I replaced the bad (used a piece out of my worn out tire) and got it all back together. You are right nothing, nothing looks worn.
2011 Cory Ness XC
psimpson is offline
