Painted Cowl Installation Help Needed - Victory Forums - Victory Motorcycle Forum
 3Likes
post #1 of 13 (permalink) Old 07-27-2017, 03:29 PM Thread Starter
WeekendRider's Avatar
Default Painted Cowl Installation Help Needed
I took advantage of the Victory blow out sale and purchased the painted lower cowl for my bike. In the process of installing it I found that the stock bolts are not long enough for the upper bolt holes on both sides (left and right.) The kit does not come with new bolts. It seems the upper bolt hole is "thicker" on the new cowls than the stock cowls.
In the pictures below you can see how much further out the bolt protrudes from the stock cowl vs. the new cowl (11/16ths vs. 5/16ths.)
The stock bolts are not long enough to grab onto the threaded side on the frame with the new cowl.
Has anyone else run into this problem?
2013 XC Suede Nuclear Sunset
21" Conversion incl. ABS Module, Rear Shock and Forks
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
Lloydz Timing Gear +4
31 Tooth Drive Pulley
Southern Motorworx Tune: 118.08 HP - 114.97 Torque (before 31 tooth drive pulley)
WeekendRider is offline
post #2 of 13 (permalink) Old 07-27-2017, 03:43 PM
post #3 of 13 (permalink) Old 07-27-2017, 03:46 PM Thread Starter
Get longer bolts.
Obviously...
But where and what size. The hardware store didn't carry black oxide bolts.
Anyone have any more constructive help?
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
post #4 of 13 (permalink) Old 07-27-2017, 03:49 PM
Take one bolt with you (obviously) to match it up and paint the exposed head of the hex bolt if needed. Does it really show?
post #5 of 13 (permalink) Old 07-27-2017, 03:51 PM
BTW; are you talking about the side plates of the chin fairing in the front of the bike or the inner fairing?
post #6 of 13 (permalink) Old 07-27-2017, 04:00 PM Thread Starter
The sides.
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
post #7 of 13 (permalink) Old 07-28-2017, 06:38 AM
If the plastic itself is thicker than the stock part, drill out the hole the same diameter as the bolt head. Do this from the outside, drilling into the recess. Drill 1/8" to 1/4" deep and re install. The bolt head will cover the unpainted hole drill and no one will be the wiser.
2012 Cross Country Tour
Sunset Red
Stage 1 / D & D slash cut exhaust
Ness RAD III mirrors
Lloyds adjustable timing system
WD Contrast Cut Shift Linkage
Kuryakyn Widow Footpegs, shift peg & brake pedal pad
Adjustable Lowering Link(1-1/2)
HeliBars
Klockwerks Flare Med. Smoke
BadBoy air horn
Ram GPS mount
GCC LED Turn Signal Relocation Kit
LED Running/turn signals in floorboards
Lazer Star 50w Driving lights
Centech AP-2 fuse panel
jim g is offline
post #8 of 13 (permalink) Old 07-28-2017, 09:47 AM Thread Starter
Thanks Jim, but the sides are cast aluminum.
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
post #9 of 13 (permalink) Old 07-28-2017, 10:10 AM
If you do decide to drill it; I would use the right flat head drill bit so you are left with a flat surface at the bottom of the hole instead of a sloped one created by a regular bit.
Also; I'd make triple sure the boss has enough meat in it before doing any drilling. Hate to see you trash the part inadvertently.
I tried looking up the bolt size but it wasn't listed in the manual I used. I'm sure it's a common metric size though.
post #10 of 13 (permalink) Old 07-28-2017, 10:47 AM
LILMAGS500's Avatar
I would NOT drill , using the proper length bolt is the correct way for you to go ... Just my opinion .
Jaak and visionjohnny like this.
LILMAGS500 is offline
