Possible transmission issue - Victory Forums - Victory Motorcycle Forum
 8Likes
post #1 of 16 (permalink) Old 08-03-2017, 05:27 AM Thread Starter
superdad1079's Avatar
Default Possible transmission issue
Hey all, just picked up a 2010 XC with 28k miles. I'm new to Victory and baggers, so this could be user error, but Is anyone having any issue downshifting from 2nd to 1st? I seem to have this problem when coming to a stop and its intermittent. I just got the XC last Thursday and didn't notice anything during the test ride, however, it seems to be more prevalent the more I ride, which is almost everyday if I can.
Also, every time I pull in the clutch completely in, I keep hitting that button that cycles the info on the dash, was that just poor engineering by Polaris, or do I have another problem on my hands?
Any help or advice would be appreciated!
superdad1079 is offline
post #2 of 16 (permalink) Old 08-03-2017, 05:45 AM
SkInM4N's Avatar
I can't speak on the downshifting issue other than the 1 & 2 on the cross bikes seem finnicky at times. Keep an eye on it.
With the the menu button issue check to see if it is your hand or the actual clutch lever pressing the button. When I first got my CCT and moved the bars to an angle I liked I then adjusted my controls. I kept cycling through the menu, resetting my clock, resetting my mileage, etc. It drove me insane for a couple of hours while I checked all the connections and finally found the issue. My clutch lever was contacting the button ever-so-slightly but still enough to push the button. I had a chuckle (and a beer) about it and fixed it and never have had the issue again.
Skin
"Trail is life..."
#rideyoureffingbike
2016 Victory CCT "Miss Pearl"
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
- Taylor Thundervolt wires
- Victory Tri-Ovals (no baffles)
SkInM4N is offline
post #3 of 16 (permalink) Old 08-03-2017, 05:49 AM
Motorbikerx's Avatar
Could be wear on your shift ratchet, doesn't take much wear for it to slip past the star wheel, especially if the slop hasn't been taken out of the shift shaft by fitting an oil drain bung washer to the shaft.
There's plenty reading about such on here, washer on shift shaft is a major improvement, requiring removal of the primary.
What speed are you going from second to first at?
You should be stopped or almost stopped to change back to first, as these engine's have enough torque to pull away in second from almost any speed.
SkInM4N likes this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 16 (permalink) Old 08-03-2017, 06:03 AM Thread Starter
"I can't speak on the downshifting issue other than the 1 & 2 on the cross bikes seem finnicky at times. Keep an eye on it.
With the the menu button issue check to see if it is your hand or the actual clutch lever pressing the button. When I first got my CCT and moved the bars to an angle I liked I then adjusted my controls. I kept cycling through the menu, resetting my clock, resetting my mileage, etc. It drove me insane for a couple of hours while I checked all the connections and finally found the issue. My clutch lever was contacting the button ever-so-slightly but still enough to push the button. I had a chuckle (and a beer) about it and fixed it and never have had the issue again."
Ya, it drove me nuts, the other day I somehow switched over from standard to metric and it was crazy I was doing like a hundred sixty miles an hour in a 55! I even accused my one friend who would just sat on my bike pushing all the buttons that he changed it and he laughed said, "no it wasn't me, but sounds like something I'd do lol." ya, I know it's the lever, but how do I fix it?
Skin[/QUOTE]
post #5 of 16 (permalink) Old 08-03-2017, 06:06 AM
SkInM4N's Avatar
Loosen the lever and move it to where the back isn't contacting the button. Mine only took a few degrees of rotation on the bars to change the angle of the clutch enough for the problem to be solved.
Skin
LILMAGS500 likes this.
"Trail is life..."
#rideyoureffingbike
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
SkInM4N is offline
post #6 of 16 (permalink) Old 08-03-2017, 06:06 AM Thread Starter
Usually tryimg between 30mph and 20mph to d/s into 1st...is my speed too high? I can usually pound it into 1st, but I'm afraid I'll break something...mongo like bike, mongo no break!
SkInM4N likes this.
post #7 of 16 (permalink) Old 08-03-2017, 06:07 AM Thread Starter
Skin
Awesome, thanks dude, I'll try that tonight!
post #8 of 16 (permalink) Old 08-03-2017, 06:14 AM
Yeah way too high!!!
What's the point of down-shifting at that speed when it'll pull second gear easily?
Stop pounding it in or you will break something.
You need to adjust your riding style to Victory they're not like other bikes.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #9 of 16 (permalink) Old 08-03-2017, 06:18 AM
SkInM4N's Avatar
No problem. Hope it helps.
Agreed. MBX makes a valid point, I had to adjust my style of riding to suit this machine and it makes a metric-shit-ton of difference.
Skin
"Trail is life..."
#rideyoureffingbike
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
SkInM4N is offline
post #10 of 16 (permalink) Old 08-03-2017, 07:01 AM Thread Starter
Thanks for all the tips gents! I'm glad, at this point it's me and not the bike, especially with a used one
