Abs fuse - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 08-27-2017, 03:50 PM Thread Starter
rainman123's Avatar
Default Abs fuse
I have a 2012 xr and need to know what is the best way to get to the abs fuses under the fender
Thanks in advance
2012 crossroad
08 r3t traded for xr
06 rocket classic totaled
98 t-bird traded for rocket
73 sportster sold
72 honda 350 long gone
06 rocket3 classic
rainman123 is offline
post #2 of 11 (permalink) Old 08-27-2017, 05:44 PM
Pauljp's Avatar
Lay down on the ground behind the rear wheel, stick your hand up her fender and unhook the two wire ends from the end caps and remove the fuses.
Paul
Gatineau Quebec, Canada
Pauljp is offline
post #3 of 11 (permalink) Old 08-27-2017, 07:44 PM
TNXR's Avatar
I guess the good and the bad about a 2011 model, no ABS.
2011 Cross Roads Sunset Red
TNXR is offline
post #4 of 11 (permalink) Old 09-17-2017, 09:04 PM Thread Starter
rainman123's Avatar
Ok I have checked my fuses cleaned the speed sensor and ring replaced the relay checked the Gap of the speed sensor changed my rear sensor changed the front sensor changed brake fluid and my abs still on anything else that I can before I take it to a dealer
2012 crossroad
73 sportster sold
06 rocket3 classic
post #5 of 11 (permalink) Old 09-18-2017, 02:42 PM
you want to clean the sensor on the front wheel both sides and check its gap. Same for the rear.
Speed sensor has nothing to do with the ABS light staying on
post #6 of 11 (permalink) Old 11-12-2017, 05:20 PM Thread Starter
rainman123's Avatar
Update
I had changed the relay with one I got from the parts store and that didn't fix my abs light
U finally got time to take it to a use to be dealer that still has the digital wrench and they said relay was bad so I finally ordered one for the xr and got it put on today and that toke care of it
I reckon I just can't use one from parts store
2012 crossroad
73 sportster sold
06 rocket3 classic
post #7 of 11 (permalink) Old 11-13-2017, 03:27 PM
Originally Posted by rainman123 View Post
Update
Hmm... I always thought a Relay is a Relay is a Relay. So I am surprised that it did not work from a parts store..
2012 Cross Country Tour - VroomHilda
Dobeck EJK Gen3 Fuel Tuner
Tri Flo Ovals
Vic K&N knock off Air filter
Lloyds Timing Wheel +2
Relocated Air Shock fill hose
WD SkidPlate reinforced
Hyper running/brake lights
Garmin GPS
Existential Secular Humorist with warrior Buddhist leanings
*Rider/Owner continuous since 1973 - 877,000+ miles USMC R
SemperVee is offline
post #8 of 11 (permalink) Old 11-13-2017, 04:58 PM
Ahoutzer's Avatar
My ABS light has been a problem since shortly after I bought the bike, six years ago. Where is this relay located on the bike?
2012 XCT (Blackbird)
Forged bars & JTD lowers
Stage 1 flash & Tri-ovals
LLoydz ATS @+6*, Air filter, Drop-in cams
VFCIII tuned by KevinX
Madstad with 13-inch shield
Garmin Zumo660
Tri-city Performance floorboard footrests
Heel shifter
Corbin saddle & backrest
Cee Bailey's bag liners
Wolo Badboy horn
KuryAkyn Sabertooth lights
Ahoutzer is offline
post #9 of 11 (permalink) Old 11-13-2017, 05:58 PM
NOEMTZ's Avatar
Up and to the right of ABS module.
www.noemtz.com
NOEMTZ is offline
post #10 of 11 (permalink) Old 11-13-2017, 08:52 PM Thread Starter
rainman123's Avatar
You will have to take the rear fender off to get to it
2012 crossroad
73 sportster sold
06 rocket3 classic
