Why fuel controller? - Victory Forums - Victory Motorcycle Forum
 4Likes
post #1 of 18 (permalink) Old 10-02-2017, 09:47 AM Thread Starter
DwayneS's Avatar
Default Why fuel controller?
I hope I'm not plowing old ground but I have a question.
I bought a new 2016 XCT this past Spring and ride it a lot. Coming up on 8000 miles already. Folks tell me that I really should put a Fuel Controller on it and some recommend the Power Commander V. I have Witch Doctors slip on mufflers and a Lloydz timing gear set at +4 degrees.
I'm satisfied with the performance as It's set up now. Exactly why do I need to spend several more $100s for a fuel controller and air filter?
Thanks
2016 CCT/2019 Roadsmith Trike conversion
2016 Cross Country Tour
2012 Cross Country - Gone but not forgotten
2008 Yamaha V Star 1100 - Nice but not very comfortable for long rides
2004 Yamaha V Star 650 - Not a road bike but short rides only
OLD Honda 750 - Started me on my road to sin AGAIN but then it was free
DwayneS is offline
post #2 of 18 (permalink) Old 10-02-2017, 09:52 AM
You don't if you're happy with the way it runs and it isn't getting too hot when riding in hot temps.
You're leaving power and possibly an even better running engine on the table without a tuner though. Remember; the company has to tune it to EPA standards which basically detunes the engine.
post #3 of 18 (permalink) Old 10-02-2017, 10:14 AM
Hi Dwayne, long time no....
This comes under the heading, Well enough should never be left alone. If you are really happy with what you got, keep your money in your pocket. But if your are close to Portland and decide to go with a dyno tune, there is a shop in my neighborhood I can turn you on to. They will install a PCV and do a dyno run for $500+.
However, there are other routes to go. Much cheaper and more effective than a dyno some say, is going with a Dobeck tuner, such as Lloydz VFCIII and adjusting it with the aid of an air/fuel ratio gauge, which I happen to have and will be doing mine shortly. Stand by for a report in the near future. Once I have mine set, I'll no longer need it and will pass it along. Next, its going to Bremerton, WA and I can have him send it to you after he's done with it.
post #4 of 18 (permalink) Old 10-02-2017, 10:35 AM
Ric, do you have the upgraded cams in your bike, if not then the Dobeck style tuner should be just fine. It's only with the cams really that the PC-V is highly recommended.
There's another one talked about here that's kinda new that I don't know much about. Can't even remember what it's called but they send you the tuner and a computer to log the results then someone connects to it via the Internet to tune the bike. It sounds like an alternative to both style tuners.
Edit: http://www.dynoguysmn.com/tuners/35t...mnhuz5atkr2wb7
post #5 of 18 (permalink) Old 10-02-2017, 11:05 AM
vindex1963's Avatar
G=3 everything else off.
Bet cha' that's what you come up with OEM Vic tuning is VERY rich under acceleration and wide open throttle and lean under cruise.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is online now
post #6 of 18 (permalink) Old 10-02-2017, 11:05 AM
Stock cams and I want to avoid the 'puter.
post #7 of 18 (permalink) Old 10-02-2017, 10:09 PM
NAB
NAB's Avatar
The less you do to you scooter. The less problems you will have.
TNXR and Blowndodge like this.
Riding: 2011 XC
Sold: 2003 Vegas
Totaled: 2003 TC, But it's still on the road.
Sold: 2004 TC
This is Just the list of Victory's. I have also rode and owned Honda's, Kawasaki's, Suzuki's, Harley's. Some old European bike. Can't remember the name. It was a 3 speed and I started riding on a 50cc bike that Sears sold. Some time around 1967. I have had my motorcycle license since 1969.
NAB is online now
post #8 of 18 (permalink) Old 10-02-2017, 11:09 PM
Motorbikerx's Avatar
If youre happy then leave it be.
I was quite happy with my Vegas too, then I bought a Ness intake filter and the rest is history.
I dont regret it one bit though.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #9 of 18 (permalink) Old 10-02-2017, 11:11 PM
NAB, if the bike had been tuned to the best possible solution the Engineers could have arrived at, without the input of the EPA, or the Governors of the corn producing states, I would agree with you. In this case however there are improvements to be made that can result in a better product.
Yes, for most of us the bike is more than adequate and none have to make any changes. Only when you push the limits do you stress the machine and increase your chance of breaking it. Those that do certainly aren't wrong, they just have more expendable $$$ than the rest of us.
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #10 of 18 (permalink) Old 10-03-2017, 05:32 AM
TNXR's Avatar
I've had mine for 5 years now and haven't done any engine mods except replace the exhaust and I have been happy with it. This is out of character for me because I modified my last bike and my current and last two trucks. I had planned on putting in a PCV, air filter, timing wheel and a dyno this summer at the Vic Rally in GA but changed my mind and cancelled my appt. Figured why mess with a good thing.
2011 Cross Roads Sunset Red
TNXR is offline
