Routine maintenance - Victory Forums - Victory Motorcycle Forum
 17Likes
post #1 of 21 (permalink) Old 10-09-2017, 05:32 PM Thread Starter
kodiakwood2's Avatar
Default Routine maintenance
When I lived in New York I would spend my winters going over the bike with a fine tooth comb. Now that we are in Tennessee it's riding time year round, so tire changing time is fine tooth comb time.
The Metzler 888's were done, the "shoulders" created by the hard center made cornering a little sketchy as the bike moved over the ridge
I'll inspect the rear shock system tomorrow, install new brake pads and bleed the brakes when the new sneakers are on.
When I pulled the front wheel I was shocked to see the ABS ring bolts were loose and one was backed out several turns
I torqued the bolts to 22 ft lbs
Eastern Tennessee
Current ride
2018 Goldwing tour
Gone but not forgotten...
Black/Chrome
Ultimate seat and driver backrest, Vic passenger backrest, Custom pinstriping by Dave Davies
Lloyds PTS @+5, Lloyds air filter, PC-V, Miller Mufflers, Lloyds Dyno-Tune,
Lloyds quarter turn throttle ring, Victory HID's, RicZ lay down bracket, Barnett "Stealth" clutch cable
kodiakwood2 is offline
post #2 of 21 (permalink) Old 10-09-2017, 06:46 PM
vindex1963's Avatar
Damn, that was a disaster...going to happen. I'm glad for you that you caught that.
Chattanooga Mark likes this.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #3 of 21 (permalink) Old 10-09-2017, 06:52 PM
theja1's Avatar
How many miles on that tire? Has a little life left in it.
Did you know 3 out of 4 people make up 75% of the population?
2003 Harley Davidson Sportster (RIP)
2006 Suzuki GZ250 (traded)
2012 Honda Shadow Phantom (traded)
2014 Victory Cross Country
theja1 is offline
post #4 of 21 (permalink) Old 10-09-2017, 07:04 PM Thread Starter
11,000 miles give or take a couple hundred
Eastern Tennessee
Current ride
2018 Goldwing tour
Black/Chrome
post #5 of 21 (permalink) Old 10-09-2017, 07:05 PM
most all tires wear out in the center cause where we ride the most.. I like the 888's
post #6 of 21 (permalink) Old 10-09-2017, 08:21 PM
theja1's Avatar
Agreed. Mine rear is wearing the exact same way. Have 15k on my Michelin Commander II so far. Probably going to run it another 3k then change it.
theja1 is offline
post #7 of 21 (permalink) Old 10-09-2017, 08:58 PM
I'd be putting some blue Loctite on those ABS ring bolts, for additional insurance.
post #8 of 21 (permalink) Old 10-09-2017, 10:14 PM
djh3's Avatar
Looking mine over as we are leaving Sat for Johnson City Tn this weekend. Battery died yesterday, so went and got a new one today. Going to change out the 40 amp Cb there by the battery being I'm there. Guess I'll look mine over a little closer on the nut and bolt.
2013 XCT added Jan 2015
djh3 is offline
post #9 of 21 (permalink) Old 10-10-2017, 07:47 AM
depot picker's Avatar
Who had the wheel off last?
depot picker is offline
post #10 of 21 (permalink) Old 10-10-2017, 11:37 AM
Why do we have a tire we like and wears good for us switch to another brand that we know nothing about and give up on what we know.
RICZ likes this.
