Going 21" Front? - Page 4 - Victory Forums - Victory Motorcycle Forum
 28Likes
post #31 of 43 (permalink) Old 05-02-2019, 11:04 AM
WeekendRider's Avatar
Originally Posted by Strew3 View Post
So does the magnum have a different fender or the same fender just reworked a bit. I believe the magnum has a 21 wheel to my knowledge.
The Magnum does come with a 21" wheel and fender. The fender is styled the same but it is larger than the fender for the 18" wheel.
2013 XC Suede Nuclear Sunset
21" Conversion incl. ABS Module, Rear Shock and Forks
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
Lloydz Timing Gear +4
31 Tooth Drive Pulley
Southern Motorworx Tune: 118.08 HP - 114.97 Torque (before 31 tooth drive pulley)
WeekendRider is online now
post #32 of 43 (permalink) Old 05-02-2019, 09:32 PM
Strew3's Avatar
So if I go to a 21” wheel with the stock fender, and have it fit but look funny, I’ll have to seek out a magnum fender to buy and paint I guess.
Eric S - NE Wisconsin
2014 Cross Country Pearl White
Ricz lay down bracket
Painted inner fairing & chin spoiler
Rear Lowered 1.5"
Ness flip shield
Ness 10 Gauge 18" Black Front Wheel
Thunderheader exhaust
Lloyd's timing wheel
PCV 5 and cams-123HP at rear wheel
Kuryakyn ignition covers
Kinetic floorboards
Vic tracker grips
Victory Motorcycles tank badge
Hidden antenna mod
Vic Black Led headlight
Victory black levers
Ness smooth fusion pegs
RF TMS6SG speakers and PBR300x2 amp
Strew3 is offline
post #33 of 43 (permalink) Old 05-02-2019, 09:40 PM
Motorbikerx's Avatar
So if I go to a 21 wheel with the stock fender, and have it fit but look funny, Ill have to seek out a magnum fender to buy and paint I guess.
or go fibreglass aftermarket but remember the front fender does act as a fork brace to some extent so I revkon steel is better.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #34 of 43 (permalink) Old 05-02-2019, 10:16 PM
Yes, if you want the same look you'll have to find a Magnum fender to buy. They are very hard to find so it may be costly.
visionjohnny and Strew3 like this.
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
post #35 of 43 (permalink) Old 05-03-2019, 11:24 AM Thread Starter
archaicguy's Avatar
I did go 21" and didn't even attempt to use the stock fender. The radius would be off and the 21" tire is quite a bit more narrow. You could use a Magnum fender or an aftermarket fender.
I went with a steel fender from RC Components.
roboots21 likes this.
2016 Cross Country
1969 Firebird
1979 10th Ann. Trans Am
1979 Solar Gold Trans Am
2010 Challenger R/T - Plum Crazy Purple
archaicguy is offline
post #36 of 43 (permalink) Old 05-03-2019, 12:19 PM
21" fender to go with the 21" wheel. I have seen an 18" fender mounted above a 21" wheel and IMHO, it looks bad. Nothing flowed right, it looked like what it was, parts mated together that weren't meant to be.
I still say a 160/60R18 front tire looks and works great. No muss, no fuss, nothing else to change.
Motorbikerx and Strew3 like this.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #37 of 43 (permalink) Old 05-04-2019, 01:12 PM
Default Looks
You'll also need the proper ABS ring for a 21" rim and technically an upgrade to your fork springs(although hardly anyone does this)
edit: I was hot on upgrading to a 21" front wheel but I finally got myself off the idea. The 21" wheel looks great but that's the only benefit.
That's the idea looks great!
Did mine no regrets.
Jackpot 50
Nuggetcharger is offline
post #38 of 43 (permalink) Old 05-04-2019, 01:19 PM
Stock 18" fender will NOT work with a 21" wheel. A 21" tire is 1" an a 1/2" inch taller so it can't fit
post #39 of 43 (permalink) Old 05-05-2019, 11:04 AM
[QUOTE=Chattanooga Mark;2554661]21" fender to go with the 21" wheel. I have seen an 18" fender mounted above a 21" wheel and IMHO, it looks bad. Nothing flowed a it looked like what it was, parts mated together that weren't meant to.
I still say a 160/60R18 front tire looks and works great. No muss, no fuss, nothing else to change.[/QU
Im finding rears in 160 60 18 but not fronts.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #40 of 43 (permalink) Old 05-05-2019, 12:52 PM
Yes they don't make a 160 front so you have to run a rear backwards. Kevinx did a perile dragon I think
