Going 21" Front? - Victory Forums - Victory Motorcycle Forum
 28Likes
post #1 of 43 (permalink) Old 11-02-2017, 05:00 PM Thread Starter
archaicguy's Avatar
Default Going 21" Front?
I'm liking the idea of going bigger on the front. Anything other than wheel, tire and fender required?
A magnum wheel would probably be the cheapest route right?
2016 Cross Country
1969 Firebird
1979 10th Ann. Trans Am
1979 Solar Gold Trans Am
2010 Challenger R/T - Plum Crazy Purple
archaicguy is offline
post #2 of 43 (permalink) Old 11-02-2017, 05:09 PM
You'll also need the proper ABS ring for a 21" rim and technically an upgrade to your fork springs(although hardly anyone does this)
edit: I was hot on upgrading to a 21" front wheel but I finally got myself off the idea. The 21" wheel looks great but that's the only benefit.
post #3 of 43 (permalink) Old 11-02-2017, 05:11 PM
This may get you the best deal on the wheel and fender: https://www.victoryforums.com/35-vict...apulpa-ok.html
I think you'll need a new ABS ring as well. The 21" kit that used to be available from Polaris also included the forks. I'm not sure what's different in the 21" wheel forks compared to the standard 18" front wheel.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #4 of 43 (permalink) Old 11-02-2017, 06:20 PM
Motorbikerx's Avatar
I went the other way ditched the 21" and went to fatter 18"
On my Vegas that is.
Much better road feel and getting double the tyre mileage as an extra bonus!
Function over form.
Motorbikerx is offline
post #5 of 43 (permalink) Old 11-03-2017, 09:33 AM Thread Starter
archaicguy's Avatar
Mine does not have abs so I shouldn't need that correct?
Thanks for the link Mark
2016 Cross Country
1969 Firebird
post #6 of 43 (permalink) Old 11-03-2017, 11:34 AM
WeekendRider's Avatar
When Victory did the big liquidation I purchased the whole conversion kit - forks, rear shock, ABS module, fender and wheel. The forks, rear shock and ABS module were all part of a kit. The fender and the wheel were each sold separately.
If your bike does not have ABS then there isn't any ring or ABS module to replace.
I went with the conversion kit to have the best chance at having the bike perform as designed by Victory. I can tell you that there is a big trade-off between looks and handling. I like the look but the bike handled much better with the 18" wheel at slow speeds than it does now with the 21" wheel. One day I would like to ride a Magnum/X-1 and compare the ride with my converted CC.
I didn't take pictures of the whole process. Replacing the rear shock was a challenge, but the ABS module is easy if the rear fender is removed and the front end changes were fairly easy as well.
Chattanooga Mark and PaiN like this.
2013 XC Suede Nuclear Sunset
21" Conversion incl. ABS Module, Rear Shock and Forks
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
Lloydz Timing Gear +4
31 Tooth Drive Pulley
Southern Motorworx Tune: 118.08 HP - 114.97 Torque (before 31 tooth drive pulley)
WeekendRider is offline
post #7 of 43 (permalink) Old 11-03-2017, 12:26 PM Thread Starter
archaicguy's Avatar
Big difference in handling huh? Not what I want to hear. I ride almost exclusively on back country winding roads and enjoy how well I can pitch it into turns now.
Gorgeous bike BTW! That 21 does look awesome on it.
2016 Cross Country
1969 Firebird
post #8 of 43 (permalink) Old 11-03-2017, 12:45 PM
Thanks!
I wish I had better news for you. It's not horrible and I am getting used to it, but the fact remains the bike handled much better with the 18" wheel.
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
post #9 of 43 (permalink) Old 11-03-2017, 01:22 PM
remember he said slow speeds not country back roads.
Now magnum is a 120 size I wonder if the handling would be better with a father 21.
I have seen where guy have put 160 fat front tires on the front and really like it
post #10 of 43 (permalink) Old 11-03-2017, 11:51 PM
I'm one of those guys. I have a 160/60 Dunlap Road Smart II MT on the front of my CCT. I love the look, form and the function of it. So far I have over 24K miles on that tire with hardly any wear showing at all.
I passed on a new 21" Magnum wheel and a new in the box gloss pearl white (my CCT color) 21" front fender earlier this week. They were being offered at $300 each. Just having to get a front fender painted would likely cost about that much. But I didn't really want to dump more money into the CCT for something I absolutely don't need. Plus I love the fat front tire so much I see no reason to change. Certainly not just for aesthetics. I also love my Victory chrome front fender bumper and that doesn't come in a 21" version either.
Question: What is different on the 21" wheel forks versus the 18" wheel forks? Would the 21" fender hit the chin fairing at full brake or fork compression?
All the best,
Mark
"Thank you."
"Who makes it?"
"No one."
