Recall on Victory Bagger Brake line routing? - Victory Forums - Victory Motorcycle Forum
 14Likes
post #1 of 39 (permalink) Old 11-03-2017, 08:55 AM Thread Starter
Question Recall on Victory Bagger Brake line routing?
https://www.motorcyclistonline.com/v...xkm7WYYBRaX.01
2012 Cross Roads
"Vixen"
bigskytruder is offline
post #2 of 39 (permalink) Old 11-03-2017, 09:23 AM
Old news! Had mine done. Took 15 minutes. Yu just need to find a dealer that is still working with Polaris for warranty claims
...."soak it all in, it's a game you can't win"
stilcrazee is offline
post #3 of 39 (permalink) Old 11-03-2017, 11:07 AM
vindex1963's Avatar
Isn't just replacing the plastic zip tie with a metal one? Big deal.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is online now
post #4 of 39 (permalink) Old 11-03-2017, 11:29 AM
I was told they move the line up (?) I think.
Tarzan likes this.
post #5 of 39 (permalink) Old 11-03-2017, 01:37 PM
Safety Risk
VICTORY ENGINEERING HAS DETERMINED THAT, IN CERTAIN CIRCUMSTANCES, SOME CROSS COUNTRY, CROSS COUNTRY TOUR, CROSS ROADS, MAGNUM AND HARD BALL MODELS MAY EXPERIENCE DAMAGE TO THE REAR BRAKE LINE. MOTORCYCLES EXPERIENCING PROLONGED MISFIRE CONDITIONS MAY PRODUCE INCREASED CATALYTIC CONVERTER TEMPERATURES CAUSING THE RETENTION CLIP SECURING THE REAR BRAKE LINE TO MELT. IN EXTREME CASES, THE RETENTION CLIP MAY MELT ONTO THE CATALYTIC CONVERTER, INCREASING THE RISK OF BRAKE LINE DAMAGE
Remedy
DEALERS TO REMOVE THE PANDUIT STRAP AND CLIP FROM THE LEFT-HAND PASSENGER FOOTREST SUPPORT AND REASSEMBLE WITH IMPROVED LINE ROUTING AND A NEWLY DESIGNED SWINGARM GUARD.
well we know now they are recalling 26 thousand bikes. So Vic's were selling pretty good
post #6 of 39 (permalink) Old 11-03-2017, 03:29 PM
sheets's Avatar
Somehow I got wind of that matter a couple months ago. Had it taken care of at a Polaris/Vic dealer while on a recent week-long outing back in September. Re-routed the brake line and put something (?) different between the line and where it makes contact with the swing arm. Quick fix - part on hand - no charge.
Chattanooga Mark likes this.
2014 XCT - blue/silver - 11" Madstad windscreen - hyd clutch - Black LED headlight -
Vic backrest - Vic short antenna - Clearwater fender-mount LED driving lights -
Vic Tri-Oval mufflers - Lloydz air filter - PC/V - Dyno tuned @ RPM, Yuba City, CA. -
sheets is offline
post #7 of 39 (permalink) Old 11-03-2017, 10:09 PM
djh3's Avatar
Hmm so if someone has say removed the CATS, you shouldnt have that issue right? Mine are still in, but just wondering. I have seen a couple pics of the fix. Probably easier for me to do it then take bike an hour and half one way.
2013 XCT added Jan 2015
djh3 is offline
post #8 of 39 (permalink) Old 11-03-2017, 10:57 PM
I had my 2012 CCT done a couple months ago. It's a 15 minute job and they do install a part. If memory serves they re-route the brake line and a wire harness on the left side where the passenger peg/board assembly bolts on. I'd suggest taking it in so the work can be properly recorded. Call ahead to ensure the dealer has the correct part in stock and ready to go. It's just another good reason to go for a ride.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #9 of 39 (permalink) Old 11-04-2017, 07:46 AM
depot picker's Avatar
I had mine done. The more significant problem in that area is the brake line appears to rub on the swing arm. The dealer would not cover this.
depot picker is offline
post #10 of 39 (permalink) Old 11-06-2017, 08:44 AM
At this point this is just a reminder. I still need to address this myself.
Victory Motorcycles Recalling Certain 2010-2017 Models
Published by Cyril Huze November 4th, 2017 i
Polaris Industries owner of the now discontinued Victory Motorcycles is recalling 26200 motorcycles (model years 2010-2017): Victory Magnum, Cross Country, Cross Roads, Tour and Hard Ball. The issue is regarding the engine potentially misfiring and and resulting in heat from the catalytic converter melting the rear brake line and nearby wiring.
Damage to the brake line or wiring could increase the risk of a crash. “Continued operation with the engine in a misfire condition can result in elevated exhaust temperatures. The rear brake line and localized electrical lines can become damaged as the result of increased temperatures.”
Dealers will re-route the brake line away from the exhaust catalyst, free of charge. The recall is expected to begin in November 2017. Owners may contact Polaris customer service at 1-877-737-7172. Polaris’ number for this recall is V-17-02.
