Mirror, mirror, on the bike. - Victory Forums - Victory Motorcycle Forum
 5Likes
post #1 of 18 (permalink) Old 11-07-2017, 09:41 PM Thread Starter
JC In AZ's Avatar
Default Mirror, mirror, on the bike.
What kind does this forum like?
I know, I know. Pretty lame effort at making a funny.
But seriously, I am not a fan of the stock mirrors on my XC. The stem is a little short, and the tear-drop style does not provide much coverage. Although I do kind of like the style of them. So, now that I've completely contradicted myself, I will re-state the question...
What style do you prefer? What brand did you go with? Did you stick with the stock ones? What's with all these questions?
Inquiring minds want to know.
Thanks
JC
"Christine" 2017 Victory Cross Country
Victory passenger backrest
Victory luggage rack
Kuryakyn driver backrest
Long Ride Shields ReCurve windshield
https://www.victoryforums.com/signat...ic169690_1.gif
JC In AZ is offline
post #2 of 18 (permalink) Old 11-08-2017, 12:12 AM
I'll start this by saying I adjust mirrors (on bike or cage) to "look" down the adjacent lane to facilitate rapid evasive maneuvers. I move my head a bit to see directly behind me. That has saved my fat many times. Consequently, I find the stock mirrors quite adequate. That's worked for me for over 65 years of riding/driving.
Some complain the left mirror is lower than the right. A free remedy is to run out the threads (there are a lot of 'em in the female hole) so to raise the mirror stem. Voila! Higher left mirror.
post #3 of 18 (permalink) Old 11-08-2017, 06:56 AM
bnhender's Avatar
Thanks
My issue with the stock mirrors was that they were so low that when I wore thicker gloves, I would constantly hit them. Victory has another mirror that has a longer stem which worked great for me.
___________________________________
Bill
2012 Cross Roads (Sunset Red)
Stage 1 flash
Lloydz Air Filter
Lloydz Idle Control Valve
Lloydz Adjustable Timing Wheel
Freedom Performance True-Dual Exhaust
VM1-DR cams
O2 Sensors disconnected
21" Adrenaline Front Wheel
Cee Bailey 24" windscreen w/ lowers
Tachometer
Small Bullet Light Bar
LED Headlight
Grasshopper driver backrest
Chrome saddlebag rails
2017 Octane
Shorty pipes
Navasota, TX
bnhender is offline
post #4 of 18 (permalink) Old 11-08-2017, 07:16 AM
Motorbikerx's Avatar
cant speak about the XC XCT mirrors , but Im ok with my stock Vegas mirrors.
Mirrors are for seeing behind and alongside me
EDIT...Only beef is they go rusty quickly
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #5 of 18 (permalink) Old 11-08-2017, 07:31 AM
I installed these at Americade, and I like them. They're heavy and solid - not as flimsy as the OEM mirrors, helps with vibrations.
https://www.kuryakyn.com/products/49...dustry-mirrors
post #6 of 18 (permalink) Old 11-08-2017, 01:50 PM
JP Cycle has all kinds of mirrors. Keep in mind you want metric mirrors cause of the threads or get Ness adapters and any of them will fit.
When I had my HD every time I sat on it I would have to adjust the mirrors for whatever reason. On the vision I have never touched the mirrors after the first time I put them in place
post #7 of 18 (permalink) Old 11-09-2017, 02:03 PM
541RF's Avatar
motorbikerx
My mirrors started to rust also, I cleaned, polished and then sprayed them with clear coat. No more rust since.
Motorbikerx likes this.
541RF
2004 Arlen Ness Signature Series Vegas
Black-Cherry Fade
Stage one dealer kit installed
Bags, tour seat with backrest and rack
Southern, OR.
541RF is offline
post #8 of 18 (permalink) Old 11-09-2017, 02:42 PM
Originally Posted by 541RF View Post
motorbikerx
Ill give that a try though theyre pretty far gone.
Mainly the stalk and nut ,not the actual mirror backing.....which incidentally look identical to the mirrors on a mates 750 Honda Shadow
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #9 of 18 (permalink) Old 11-09-2017, 03:07 PM
541RF's Avatar
Yea, that is what was rusting on my bike. both stems and retaining nuts. Cleaned the rust and some chrome then buffed it out.
541RF
Black-Cherry Fade
Southern, OR.
541RF is offline
post #10 of 18 (permalink) Old 11-09-2017, 08:40 PM
another job to put on the list....I was thinking of black heat shrink but thatd not suit this bike
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
