XCT starter noise and solution - Victory Forums - Victory Motorcycle Forum
 5Likes
post #1 of 14 (permalink) Old 12-11-2017, 05:02 PM Thread Starter
ostbob's Avatar
Default XCT starter noise and solution
2012 XCT bought with 3000 miles on it and the starter would always make a grinding noise when it was cold outside. It now has 31,000 miles on it and was still doing it so I had the starter replaced. That solved the problem.
Here is a youtube of the noise it was making and I will attach pictures of what I found inside the starter. It appears the armature was rubbing against the magnets inside. Just to tight I guess.The black at one end is from the brushes so I don't think that had anything to do with it.
Just can't figure out why after all the hundreds of starts it didn't just wear away the two parts that were touching???? Probably could of gotten another 30,000 miles out of it but it was bugging me and would certainly hurt RESALE VALUE.
Bob
Retired law enforcement
Ex-USCG
2012 Victory XCT,
floor board skid plates,
tankslapper 3M paint protection.
Magic Strobe modulationg trunk brake lights
2" pull backs
Russel Day Long seat
Kriss Industries Headlight modulator
Doran tire pressure monitoring system
ostbob is offline
post #2 of 14 (permalink) Old 12-11-2017, 08:01 PM
Badger56's Avatar
I my self had the same problem once weather got cold. I removed the starter took apart and cleaned it up and re lubed it now works better then when bike was brand new.
Badger56 is offline
post #3 of 14 (permalink) Old 12-11-2017, 08:38 PM
Thank you for starting this thread. I've heard of this starter issue but never heard what it sounded like until your video. Yikes, that does sound awful.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #4 of 14 (permalink) Old 12-11-2017, 08:48 PM
Motorbikerx's Avatar
GAWD!!! Sounds like theres a rooster in there!
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #5 of 14 (permalink) Old 12-11-2017, 09:08 PM
take that armature to a machine shop and have them take .010 off the armature. It should be a good spare at that point.
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #6 of 14 (permalink) Old 12-11-2017, 09:24 PM
Yeah...do what Joe recommends and have them clean the commutator and install new bearings while you're at it. A spare is always good to have around.
post #7 of 14 (permalink) Old 12-11-2017, 10:29 PM
Default Starter
This thread is "just getting started"! Maybe he used the wrong engine oil! Ha, ha!
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
post #8 of 14 (permalink) Old 12-12-2017, 08:38 AM
Bueller's Avatar
It wouldnt even hurt if he just carefully ground down the armature area where its rubbing.
Bueller is offline
post #9 of 14 (permalink) Old 12-12-2017, 10:09 AM
Mine has done that a handful of times but not on a regular basis and only when very cold, I thought it was feedback of some sort through the speakers, glad I know what it is now. And a good idea as to a solution for it too.
2012 Victory Cross Country Tour, Sunset Red.
Parts added to make her louder, faster and more mine.
Stage 1 filter and pipes, Lloydz VFIII & ATW.
Clearwater Darla, LED GLO, emergency lights and siren.
Bushtec hitch and harness, Kompact Kamp trailer.
ChuglyXJ is offline
post #10 of 14 (permalink) Old 12-12-2017, 12:08 PM
starters are very easy to rebuild. Brushes and bearing you can get from local shops. Youtube has a bunch of how to's. Once rebuilt some one will be looking for one
