upgrade advice - Victory Forums - Victory Motorcycle Forum
 24Likes
post #1 of 31 (permalink) Old 12-16-2017, 07:46 PM Thread Starter
psychodiablo's Avatar
Send a message via AIM to psychodiablo
Smile upgrade advice
currently have loyds filter,gen 3 fuel controler and triovals. thinking of the timeing wheel. suggestions please.
Leesville Louisiana. 2012 cross country, speedo upgrade,forged engine guard,touring sheild, tri oval pipes, Lloyds gen 3 fuel controler, Lloyds highflow airfilter. Lloyds timeing wheel, msd coils,Lloyds 8.2 mm red wires,tank lift/spacers,tank wings,side cover scoops,audio input cord,drivers back rest, 2in pull back bars,polk 5.25 speakers,XC Mag baffles,rockford fosgate pbr400x4 amp,lower wind deflectors,sylvainia ZXE Gold h-11 headlights. rivco hiden hitch. IDMW,FYIYDLMOMB.
psychodiablo is offline
post #2 of 31 (permalink) Old 12-16-2017, 09:09 PM
BP6666VR's Avatar
Quarter trotle ring....
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 31 (permalink) Old 12-16-2017, 09:12 PM Thread Starter
looks simple to do but is there any real binifit to it. the play in the twist isnt bad to me. also been looking at af ratio guages and dam there is so frekn many.
post #4 of 31 (permalink) Old 12-16-2017, 09:13 PM
VicVisionBulldog's Avatar
I really enjoy my timing wheel. I wish I added it sooner.
jazzdogg likes this.
VVB
13 Vision Tour - PCV, Top Filter, Stage 1 Pipes, TW @ +4, Metz 888s
VicVisionBulldog is offline
post #5 of 31 (permalink) Old 12-16-2017, 09:16 PM Thread Starter
i dont plan on to much more stuff for it. i really dont want to go as far as doing cams. i am trying to stay out of the engine as much as i can. the maximus stuff sounds good.
post #6 of 31 (permalink) Old 12-16-2017, 09:19 PM
If you get a Maximus it can adjust the timing so you wouldn't need the timing wheel.
With your current setup the timing wheel would smooth out the motor in the first few gears. Like I said I'm very happy with mine. I was surprised at what it did but it was all good.
VVB
post #7 of 31 (permalink) Old 12-16-2017, 10:28 PM
BP6666VR's Avatar
I agree with @VicVisionBulldog if you would just go to a tuner and get that Maximus thing and a DYNO, then you only "loose" the money you paid for the Gen3 fuel controller .... and then you are done with the power mods on this bike,
The quarter throttle ring is just much easier on your ride, and super cheap, I made one myself, coz 1 forum member posted a vid how to do it .... See attached the stock vic gas grip with throttle ring compair to a aftermarket grip that I'm modifying for my jackpot....
RICZ likes this.
BP6666VR is offline
post #8 of 31 (permalink) Old 12-16-2017, 11:35 PM
Seems like we're twins separated at birth as we both like the cheap and easy. Here's what I did and I am very please with the results and the small cost, compared to other methods of tuning. I too have a Lloydz VFCIII fuel controller, but it always bothered me that I was in the dark as to what the AFR ratios were. So I grabbed a used digital AFR meter that a forum member was selling and did a temporary mount on my bike. While riding, I took note of the fuel ratios and adjusted the controller accordingly. Now it runs a tad on the rich side in all conditions, including idle, cruise and acceleration. The huge advantage is its done in REAL WORLD conditions, not on rollers. BTW, I also bought the controller used from a forum member, and those two cost me less than $250. Oh...and my adjustable timing wheel is set to 5+. She runs very strong and smooth now. Here's a link to the meter I have....Its very easy to set up and read and there's good help here from more than just me....
MTX-L PLUS Digital Wideband Air/fuel Ratio Gauge
post #9 of 31 (permalink) Old 12-17-2017, 07:58 AM
TNXR's Avatar
I don't know Ricz, I maybe the cheapest here because I haven't done a darn thing to my XR to upgrade performance! Am I the only active member on here who has owned their cross bike for 5+ years and not touched the performance side of it?
2011 Cross Roads Sunset Red
TNXR is offline
post #10 of 31 (permalink) Old 12-17-2017, 08:31 AM
CanuckRob's Avatar
The 1/4 turn throttle ring is totally awesome...i was skeptical about it but i wouldn't be without it now not only does it make for no pain in the wrist it changes the response of the bike IMHO
Ride Safe,
Rob
2010 Cross Country -
Elmvale ON Canada
Stage 1
Chrome Tri Ovals
Lloyds 1/4 turn throttle ring
Kuryakyn heel toe shifter
OEM high performance air filter
CanuckRob is offline
