Extreme 6 Speaker Fairing Audio & Amp Kit - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By tdicamillo
post #1 of 3 (permalink) Old 01-30-2018, 07:20 PM Thread Starter
tdicamillo's Avatar
Default Extreme 6 Speaker Fairing Audio & Amp Kit
I just ordered one of these kits on clearance from LeadersRPM and when I received the kit something was clunking around in the new ABS box. Looking inside the box I see the crossover's coil dangling around. This was the case for both left and right boxes! After opening up the clam shell chase and found a thin plastic film that was supposed to be wrapped around the coil torn apart and the coil was just hanging by it's 2 wires. Easy fix, just zip tie it the back down to the PCB.
Just wanted to mention it in case someone has a set installed and hears some extra rattles in the fairing, it may be these coils.
Also those magnets on the back of the 4 1/2 speakers seem puny. Hopefully they sound better than they look.
The wisest men follow their own direction. ~~ Euripides ~~
2015 Cross Country - Havasu Red with Black Flames
Stock of now
2006 Hammer - Yellow with Tribal Graphics
Bought it used don't have much history on mods.
tdicamillo is offline
post #2 of 3 (permalink) Old 01-30-2018, 07:40 PM
Good for you, I didn't know they had any of those left. I installed one on my CCT a few months ago. I'm very pleased with this kit as well as the Extreme Saddlebag Speaker Kit. I did a write on installing both of them on this forum.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #3 of 3 (permalink) Old 01-30-2018, 09:42 PM Thread Starter
tdicamillo's Avatar
Thanks for that writeup. I read it before pulling the trigger to purchase.
Sent from my SM-G950U using Tapatalk
Chattanooga Mark likes this.
Stock of now
