Ecu flash - Victory Forums - Victory Motorcycle Forum
 10Likes
post #1 of 15 (permalink) Old 02-13-2018, 03:58 PM Thread Starter
cpeyton23's Avatar
Default Ecu flash
Hey what’s up guys, I have a buddy that’s about to get cams installed on his cc. The dealership told him that he wouldn’t need a fuel management system, they will just reflash his ECU. Have you guys ever heard of this.
2013 cross country,26" front rim
cpeyton23 is offline
post #2 of 15 (permalink) Old 02-13-2018, 04:23 PM
His dealership is full of hogwash. He will need a tuner and a tune at the bare minimum. A dyno tune if he wants to wring every last bit of good power out of it. If he doesn't have any tuner at all right now (like a PC-V) then tell him about the Maximus. Depending on his air filter, exhaust, and if he has a timing wheel, there are some canned MAPs (tunes) available for the PC-V if he wanted to go that route.
This isn't one of those easy answer questions other than to say there's no point in getting the stage one flash which is all a dealership can legally do.
visionjohnny and BP6666VR like this.
BBob is online now
post #3 of 15 (permalink) Old 02-13-2018, 04:56 PM
BP6666VR's Avatar
Completely agree with @BBob,
better get the cams done in a GOOD place who understands motorcycles... Surly there is a vic guru in your vicinity ¿
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is online now
post #4 of 15 (permalink) Old 02-13-2018, 08:43 PM
NOEMTZ's Avatar
If he is doing the S&S kit, it comes with an ECU reflash card.
half_crazy likes this.
www.noemtz.com
“I DON’T PICK SIDES, GO WITH THE FLOW, OR PUT UP WITH BULLSHIT.
I RELY SOLELY ON MYSELF, BEAUSE I HAVE MY OWN BACK. NOEMTZ - 2010”
NOEMTZ is offline
post #5 of 15 (permalink) Old 02-13-2018, 08:56 PM
That's a new one on me. Thanks Noe! Do you know if the S&S kit for a 2004 KP comes with a flash card too?
BBob is online now
post #6 of 15 (permalink) Old 02-13-2018, 09:18 PM
NOEMTZ's Avatar
The factory only did the reflash cards with the S&S cam kits for the cross country platform bikes only because it came with a specific air dam, filter and a disclaimer stating that tri-oval exhaust was required as part of the complete kit. But triovals also had to be purchased separately.
visionjohnny and half_crazy like this.
www.noemtz.com
NOEMTZ is offline
post #7 of 15 (permalink) Old 02-13-2018, 09:22 PM
NOEMTZ's Avatar
https://www.cycleworld.com/victory-m...rmance-cam-kit
www.noemtz.com
NOEMTZ is offline
post #8 of 15 (permalink) Old 02-13-2018, 09:34 PM
BBob is online now
post #9 of 15 (permalink) Old 02-14-2018, 04:58 AM
half_crazy's Avatar
And a stage 1 Cross Country (Lloyd air filter, slip-ons, and a Maximus tuner) will make the same power as the "Victory/S&S Stage 2" equipped bike without touching the engine at all.
Add cams to the stage 1 bike and it will leave the "Victory/S&S Stage 2" equipped bike for dead... like it was chained to a post.
1st mistake: Didn't research it.
2nd mistake: Listening to what anyone at a dealership says.
3rd mistake: Trying to take the cheap and easy route, which is always a poor decision. Best results come from doing it once and doing it right... by whatever means necessary... because the worst thing in life is disappointment/regret. Nothing like spending $1000 and then riding the bike thinking, "That's it? A thousand bucks for this?".
visionjohnny, BP6666VR and kaitiff like this.
2006 Victory Kingpin
half_crazy is offline
post #10 of 15 (permalink) Old 02-14-2018, 06:23 AM
BP6666VR's Avatar
Wise words HC.... As you know for us at the other side of the world it is even more complicated, so because of the good people of this forum i have planned all the boltons carefully, the only thing that was out of my hands was the exhaust, and that ended up as the top 3 best exhaust .... Only 2 in 1 is better, but who cares....
I hope the OP will do the right thing and get his "friend" to join this forum so he can do it the first time right....
