Picture of air line routing? - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By RICZ
post #1 of 4 (permalink) Old 03-12-2018, 03:35 PM Thread Starter
Amboymike's Avatar
Default Picture of air line routing?
Pulled the shock and link cleaned and lubed, everything is back but the air line is closer than I like
to the frame.
Does the air line go through the large plastic loop on the splash guard along with the
vent hose?
_____________________________________
2012 Crossroads
Amboymike is offline
post #2 of 4 (permalink) Old 03-12-2018, 03:43 PM
Default ?
Yes it does, the way I remember it. The plastic has a preformed clip molded into it. My bike runs the Penske shock now.
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
post #3 of 4 (permalink) Old 03-12-2018, 04:23 PM
This would be a wonderful time to place an extension on the air hose so that the valve is just ahead of the side cover. That way, you don't have to remove the cover to check air. I did that am I ever glad I did.
TNXR likes this.
post #4 of 4 (permalink) Old 03-12-2018, 04:56 PM
TNXR's Avatar
I strongly second what Ricz said. I relocated mine a few years ago because I ride 2-up half the time plus take some weekend trips with the bags loaded down so I am always adjusting the pressure.
2011 Cross Roads Sunset Red
TNXR is offline
