Replacing HID headlight with LED - Victory Forums - Victory Motorcycle Forum
 10Likes
post #1 of 22 (permalink) Old 03-19-2018, 11:28 AM Thread Starter
Default Replacing HID headlight with LED
Hey guys,
I just bought a beautiful LED headlight at Daytona Bikeweek to replace the HID (low beam only) light on my 2011 X-country. I happily unscrewed the current light only to discover that the HID has a completely different plug and comes with a ballast. Before I screw something up, am I correct in assuming the ballast needs to be removed and I somehow need to get the original plug back on the low beam wiring? Any advise is appreciated.
Jack
Black 2011 Cross Country
Victory Sissy bar
Lloydz power commander, stage 1 pipes
Kuryakyn Sabertooth taillight accents
Chrome switch panel cover
Av8rguy is offline
post #2 of 22 (permalink) Old 03-19-2018, 01:50 PM
If you have the factory HID headlight, you should also have the 'regular' headlight connections in your fairing wire harness. When you remove the fairing you should be able to find them. Removing just the headlight may not give you access to everything. Yes, the entire headlight assembly, the ballast and the ballast wiring will be removed.
As an aside, the factory HID is a lot better headlight than an LED headlight. The HID spreads a lot of light low and to the sides as well as down the road. The LED has such a focused beam of light as to leave the sides devoid of anything. Hence the 'adaptive' LED headlight which tries to make up for the loss of LED light low and wide. I have a 2012 CCT with the factory HID and would not want to trade it in for any LED system I've ever seen.
When you remove your factory HID headlight and ballast with the wiring, let me know as I may be a candidate for another spare factory HID system. If it's an aftermarket HID system, I'd not be interested in it at all.
SemperVee and roadcouch like this.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #3 of 22 (permalink) Old 03-19-2018, 04:12 PM
olddad64's Avatar
I put LED's in my 2014 CCT and all I did was take out the other bulbs and put in the new and it all Pluged in. The LED's did have a bigger base and I had to cut out a brace in back of headlight area so they would work, which took some time, and I had to move some wires around too to make room but I did it and like my LED Headlight. I think I did a post on the installation and showed where I cut out but can't remember cause I'm old. I think this is the picture of what I did. Maybe I helped you a little bit. Hope it works out ok for you and the light you have..
2014 Victory Cross Country Tour. Blue and Silver
Tri-Ovals--Stage 1 download--Loydz Air Filter
Sabertooth Saddle Bag Lights
LED headlights and a few custom engine/transmission goodies
olddad64 is offline
post #4 of 22 (permalink) Old 03-19-2018, 06:05 PM Thread Starter
Thanks for the quick reply Mark, I will remove the fairing and see what I can find, fingers crossed.
Once I remove the HID kit, I'll take a picture of it so you can see if you want it.
Chattanooga Mark likes this.
Victory Sissy bar
Av8rguy is offline
post #5 of 22 (permalink) Old 03-19-2018, 06:07 PM Thread Starter
Thanks Olddad, in this case I believe Mark's reply is closer to what I need.
Victory Sissy bar
Av8rguy is offline
post #6 of 22 (permalink) Old 03-19-2018, 07:54 PM
FWIW....My combo is an LED in the low beam so I don't dazzle oncoming and an HID in the high beam. I'm liking it.
post #7 of 22 (permalink) Old 03-20-2018, 04:46 PM
DwayneS's Avatar
Default just take it out
Remove and unplug the HID bulb and ballast. The LED should plug in where the HID was plugged. The plugs are labeled upper and lower. The upper is the low beam.
RICZ and SemperVee like this.
2016 CCT/2019 Roadsmith Trike conversion
2016 Cross Country Tour
2012 Cross Country - Gone but not forgotten
2008 Yamaha V Star 1100 - Nice but not very comfortable for long rides
2004 Yamaha V Star 650 - Not a road bike but short rides only
OLD Honda 750 - Started me on my road to sin AGAIN but then it was free
DwayneS is offline
post #8 of 22 (permalink) Old 03-21-2018, 02:00 PM
BenD's Avatar
Remove the fairing and look for a yellow and a black wire H11 connector. It will be along the left side as you face the bike. You might be able find it by following the high beam wires, which are green and black. You can leave the HID stuff alone or remove it, as you wish.
2012 XC Tour, Sunset Red/Silver PC-5 Thrush mod pipes Lloydz air filter and timing wheel.
California Sidecar Trike Conversion
Phoenix, AZ
BenD is offline
post #9 of 22 (permalink) Old 03-21-2018, 05:21 PM
Motorbikerx's Avatar
Im using and love Crossroads VICTORY HID systems on both hi and lo beams.
jerparker1 likes this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #10 of 22 (permalink) Old 03-22-2018, 07:37 AM
gamewarden's Avatar
I also have the Victory HID only on high beam now. There is no better light out there. I had it on the low beam which I liked but the ballast went on me so I went back to the Original bulb. You cannot beat the HID at night. Paul from Ottawa did a video comparing the different lights.
2011 custom Tequila Gold with Candy Orange accents, hard lowers and trunk, Ipod in lowers, HID and saddle bag bars, stage 1, heel shifter, front and back chrome fender guards,Garmin GPS, fairing wind deflectors, heated Gerbing hook up, Dain skull brake pedal, rear brake master and reservoir cover, custom cheese wedge cover, clutch cover, Witchdoctor cam covers, Wolo Bad Boy horn, heated grips and seat, Gorilla alarm, Vision rear engine brackett covers, Kruzer Caddy, WD exhaust tips.
gamewarden is offline
