Side Cover Warning XC / Mag Side Cover Grommets - Victory Forums - Victory Motorcycle Forum
 23Likes
post #1 of 21 (permalink) Old 04-11-2018, 06:22 PM Thread Starter
Bueller's Avatar
Default Side Cover Warning XC / Mag Side Cover Grommets
I didn't like how my side panels were fitting. I just ran some safety wire to them for insurance So they dont come off. While ordering some parts I decided to get a set of these grommets. Good thing I did. The old ones are on the bottom. These are from a 2016 1200 miles. It only saw a few trips last summer. I tried electrical tape around the spade and IMO it only made the fit worse. New ones are a night and day diff. Who ever makes these needs to keep making them!!! Mine were dated 12/17 I expect to be replacing these next spring. [IMG][/IMG]
16 Magnum Midwest USA
Bueller is offline
post #2 of 21 (permalink) Old 04-11-2018, 08:53 PM
depot picker's Avatar
Just make sure the wires behind the cover aren't interfering.
Chattanooga Mark likes this.
depot picker is offline
post #3 of 21 (permalink) Old 04-11-2018, 09:15 PM Thread Starter
Bueller's Avatar
After reading about all the M8 Harley problems in the last couple of days....I felt I needed to take the time and post up this warning for everyone. I dont know whats worse. Blown head gaskets or valve seats falling out. I guess I will never know anymore.
Bueller is offline
post #4 of 21 (permalink) Old 04-11-2018, 10:45 PM
BP6666VR's Avatar
Can you measure
I.D. = xx milimeter
O.D. = xx milimeter
Thik . = xx milimeter
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #5 of 21 (permalink) Old 04-12-2018, 07:22 AM Thread Starter
Bueller's Avatar
I would use my veniarial calipers but they are kind of porous. In fact, there is oil leaking out of them and I can't figure out where its coming from. I could try a dial bore gauge but the oil pump has seized the piston. Hopefully I can return for a refund.
Just heard back from the factory. They are going to replace the piston and the cyl and since only one piston seized, we will not be replacing the other side. I Figure that's fair enough. The tool was thoroughly damaged but since only one piston seized....well that's all they are going to replace. Strand you later.
Bueller is offline
post #6 of 21 (permalink) Old 04-12-2018, 12:52 PM
Huh? I don't understand what this has to do with the grommets. Whatever it is about, it sounds bad. Please elaborate - although probably in a new thread.
G'day,
Vinish
Our patriotic stable:
Red 2012 XCT (my bike for NC)
Vinish is offline
post #7 of 21 (permalink) Old 04-12-2018, 10:37 PM
I've read on the forums that Honda uses the same sized grommet but of a better material to the ones Polaris chose. I'll try to find a link to the Honda item number and will post it if I find it.
BP6666VR likes this.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #8 of 21 (permalink) Old 04-14-2018, 07:33 AM
Ahoutzer's Avatar
Maybe itís because my Blackbird is a Tour model, with passenger floor boards, rather than pegs, but I can barely get the side covers off when I want to! Also, Blackbird has BBobís heat deflectors under the gas tank, hanging down over the side covers. Those further secure the side covers from coming off or even being taken off intentionally. All of that said, I do not find the side covers loose, either. It does require considerable care to seat all three posts in the holes whenever reinstalling the side covers.
2012 XCT (Blackbird)
Forged bars & JTD lowers
Stage 1 flash & Tri-ovals
LLoydz ATS @+6*, Air filter, Drop-in cams
VFCIII tuned by KevinX
Madstad with 13-inch shield
Garmin Zumo660
Tri-city Performance floorboard footrests
Heel shifter
Corbin saddle & backrest
Cee Bailey's bag liners
Wolo Badboy horn
KuryAkyn Sabertooth lights
Ahoutzer is offline
post #9 of 21 (permalink) Old 04-14-2018, 10:08 PM Thread Starter
Bueller's Avatar
Thing is we all know how they feel coming off and putting on. Its the several poor sobs that talk about them blowing off gone forever or busted up on the road. How does this happen? Dust and dirt has easy access to get into the grommet holes from the back. Its a matter of time. Would you know if one of them just blew off your bike?
Speedblue likes this.
Bueller is offline
post #10 of 21 (permalink) Old 04-15-2018, 12:36 AM
Default Off
Bueller years ago right after I got my XR I lost the left side cover. No I never felt it come off. Now the other thing is I guess as expensive as they are somebody may have borrowed the side cover from my bike. It they borrowed it I never got it back. Very expensive the way I remember it, I did not have the bike for two weeks when I lost one.
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
