Cobra Stage 1 Tri Ovals rust stain issues. - Victory Forums - Victory Motorcycle Forum
 21Likes
post #1 of 18 (permalink) Old 04-12-2018, 04:29 PM Thread Starter
Dusty Boots's Avatar
Default Cobra Stage 1 Tri Ovals rust stain issues.
I saw on another web site that a few people were having issues with rust stains running out from there new Tri Ovals.
One member added a couple of photos of his new ones that had rust stains/rust running out of the rear and he was constantly wiping it off.
Having recently acquired the Tri Oval Stage 1 kit in chrome myself, I was rather concerned about that, so I decided to remove the baffles and investigate why that would happen.
I found what most likely is the source of the rust stains. Keep in mind, my pipes are brand new and have never been run yet, so they haven't been subjected to a build up of condensation yet.
I saw rust forming around the welds by the Y-Pipe. I cleaned the top baffle up a bit with a brass wire whell, but hadn't touched the bottom one yet and you can see the rust forming.
Dusty
2013 Victory XCT - SW Ontario
Stage 1 Victory Tri Oval kit, with EFI retune
Lloydz Timing Wheel (+4)
Quarter turn throttle ring
It's never too early to plan and never too late to go!
Dusty Boots is offline
post #2 of 18 (permalink) Old 04-12-2018, 04:30 PM Thread Starter
I decided to clean then up with the brass wire wheel and coat them with a couple coats of Rust Oleum Specialty High-Heat Ultra Black Spray Paint to hopefully help prevent that from happening to mine.
Hoping that will prevent the rust stains for a couple of years.
Dusty
post #3 of 18 (permalink) Old 04-12-2018, 05:16 PM
I have not seen any signs of corrosion on my Tri's and they are a few years old now. But this is easy enough to do and might prevent issues in the future... Thanks for the tip
Chattanooga Mark likes this.
post #4 of 18 (permalink) Old 04-12-2018, 09:40 PM
olddad64's Avatar
Are Tri-Ovals that easy to pull apart ? WOW...I may do that to mine. Maybe add a little bit of SS wool to cut down on the sound a bit.
THANKS for the info and pictures ! !
2014 Victory Cross Country Tour. Blue and Silver
Tri-Ovals--Stage 1 download--Loydz Air Filter
Sabertooth Saddle Bag Lights
LED headlights and a few custom engine/transmission goodies
olddad64 is offline
post #5 of 18 (permalink) Old 04-12-2018, 10:33 PM
Great post and photos Dusty, thank you. I like how you cleaned yours up to prevent a possible rust issue going forward. I also have a brand new set of Tri Ovals in my garage and will now likely pull the baffles to clean and paint them like you've done.
I've read several times that cutting off the baffle and leaving a 3" stub on the Y connector greatly improves the sound of the Tri Ovals.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #6 of 18 (permalink) Old 04-13-2018, 02:14 PM
Dusty Boots
Heat up the pipes a little at a time. Maybe 10 min and shut bike off let it cool down that repete. If you go for a 30 mile ride right off the bat you'll burn up the paint
post #7 of 18 (permalink) Old 04-13-2018, 03:00 PM
doobliss's Avatar
Dusty Boots
That process is necessary even with high temp paint?
'15 Gloss Titanium XC.
WOLO Low Tone Disc Horn
Tri-Oval Slip Ons
Black LED Headlight
Kingpin Metal Fork Guards
Ricz Lay Down Plate
Lloydz Timing Wheel & Throttle Ring
Shinhopples Grip Covers
12" Long Ride Shield
Bad Ace Billet Fork Mounted Air Deflector
Ness Signals; Amber front, Red rear
http://www.pure-gas.org/
"I leave the BUG CARNAGE on my screen , it adds character!"-LILMAGS500
doobliss is offline
post #8 of 18 (permalink) Old 04-13-2018, 03:06 PM Thread Starter
Yes, it needs 'breaking in'!
Dusty
post #9 of 18 (permalink) Old 04-13-2018, 04:16 PM Thread Starter
I installed the left side baffle and thought I'd take a peek up inside the tube of the right Tri Oval and this is what I found! ....
..... which could be the true source of the rust streaks! Thoughts ????
post #10 of 18 (permalink) Old 04-13-2018, 05:22 PM
Motorbikerx's Avatar
Short trips...ya gotta go on longer rides to heat the pipes up properly and get rid of condensation..
Ride more and for longer is the cure.
Good for the soul too
Chattanooga Mark and doobliss like this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
