Front Brakes - Victory Forums - Victory Motorcycle Forum
 21Likes
post #1 of 22 (permalink) Old 04-27-2018, 12:02 PM Thread Starter
JJKJR's Avatar
Default Front Brakes
For a few months, when I apply my front brakes they do not stop the bike smoothly like my rear brakes. The best way I could describe the front braking are they stop the bike "jerky." The jerking motion is enough that I feel the front shocks compress during the jerking. I have an appointment next week with a mechanic but would like to understand some possible causes so that I can make a better decision for the repairs. Thanks for your assistance.
2014 Havasu Red XC
2004 Black Suzuki Volusia
JJKJR is offline
post #2 of 22 (permalink) Old 04-27-2018, 12:17 PM
I like to try the cheap and easy things first, so here's what I'd do....
+ Sounds like you might have something on your front discs, so take brake cleaner or alcohol and wipe them off.
+ Rub them with a very fine sandpaper or a Scotchbrite pad.
+ Remove the pads and rub them on a piece of sandpaper that's on a flat surface.
+ Wipe pads and discs down with brake cleaner again to get rid of and debris from the sanding.
+ If you still have the crappy OEM pads, this is a good time to move up to EBC HH pads - they'll make for a big improvement in stopping power.
post #3 of 22 (permalink) Old 04-28-2018, 04:11 AM
TNXR's Avatar
I put the EBC HH pads on mine a couple of months ago and Ricz is right, they will stop you in a hurry! The only downside is that the EBC's are kind of noisy where the OEM's were not.
visionjohnny likes this.
2011 Cross Roads Sunset Red
TNXR is offline
post #4 of 22 (permalink) Old 04-28-2018, 06:28 AM Thread Starter
JJKJR's Avatar
Thanks for the suggestions. I'm thinking my brake pads need replacing and have read that the EBC HH pads are much better than the OEM ones. I'll write back next week some time to let you know what turned out to be the problem(s).
2014 Havasu Red XC
JJKJR is offline
post #5 of 22 (permalink) Old 04-28-2018, 06:59 AM
BP6666VR's Avatar
Was the bike new or second ? Maybe some oil was spilled on your pads, so yes please change them ... I loved the EBC pads, but they did not last very long, and they were noisy at the last meters of a stop,
So i bought lyndall brake pads, and they work the same (maybe better) as EBC, but last longer .... And no noise at the last meter on stopping, (i think in the rain , but i forgotten)
Andre using TaPaTaLk
Motorbikerx likes this.
Cross Country Tour 2014 [B]
BP6666VR is offline
post #6 of 22 (permalink) Old 04-28-2018, 07:01 AM
BP6666VR's Avatar
Hmmmm reading back my post it sounds confusing ....
Ha ha, but i ment no harm
Smile
BP6666VR is offline
post #7 of 22 (permalink) Old 04-28-2018, 09:36 AM
I replaced my oem brake pads with Lyndall Gold from Witchdoctors a year or so ago and love them. As quiet as the oem pads but with superior grip and stopping power.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #8 of 22 (permalink) Old 04-28-2018, 12:13 PM
JJKJR
be careful of the dealers BS. He might try to tell you rotors are warped when there not. Stand in front of bike and with flash light look down at the calipers you should be able to see the thickness of the pads
Chattanooga Mark likes this.
post #9 of 22 (permalink) Old 04-28-2018, 06:20 PM Thread Starter
JJKJR's Avatar
VJ, I truly understand the dealer BS, that's why I wrote here first so I could have some possible ideas of what might be going on. Thanks again to all of you for your comments/suggestions.
2014 Havasu Red XC
JJKJR is offline
post #10 of 22 (permalink) Old 04-29-2018, 01:05 PM
say maybe the what's called buttons on your rotor are gummed up. I believe there is 9 of them. There the round circle that holds the center of the rotor to the outer rotor. If you do the brake clean squirt some in each of them to make sure there free
